Can anyone give me demensions of factory ride height and where to measure from? What diameter tire if this makes a differance
thanks
In 1967 the riding height measurement varies depending on the engine size. All of the specifications are listed in the 1967 Chevrolet Chassis Overhaul Manual.
It's also found in the Chevrolet Camaro factory assembly manual, UPC 3 starting on sheet A8. You have to compute the correct Z & J measurements by figuring in your specific model, all your options, engine, trans, tires etc. Then you move on to UPC 4 to similarly compute the K & D measurements for the rear. The location to take these measurements is also shown.
