You can upload pictures directly from your computer or phone to include in your post by using the "Attach" box. The "Attach" box shows when posting a new topic or a reply, but not when using "Quick Reply".
Images must be 200 KB or smaller. There's a maximum of 4 attachments per post and the total of all of them can't be more than 500 KB. Make sure you crop the picture(s) to show only what needs to be shown.
Many (free) programs out there that resize picture files - almost any photo program does it. If you resize the pictures right, they don't have to be big files to be clear. Just downsize them to 700 or 800 pixels wide. If you keep the jpg quality factor lower (50 or 60 is fine), it takes up a lot less space than at 80-90 with little change in picture quality.
I use http://www.irfanview.com/ - works well and is free.
Many use http://www.obviousidea.com/windows-software/light-image-resizer/ - also free.
You can also to a picture hosting site like Flickr (https://www.flickr.com/) or Google (https://www.google.com/photos/about/). Both are free and pretty easy to use.
You can then copy the direct IMG code from the hosting site and paste it directly into your post. Again, you want to keep the size down to 700-800 pixels wide so it fits on the screen without scrolling and so it doesn't take forever to load for people with slower connection.
Lastly, you might change the file name as you save it so you still have the high resolution version (I just add an e to the end of the file name so I know it's been edited).
Thanks KurtS I will attempt it once again with your advice. Jimbo :) :) :)
I am new to this but I have a 67 camaro I need help with
Well if you have a PC you need to re-size the pic(s) to under 200KB. If you have a mac the easiest way I have found is to take a screen shot and then go tot tools to resize the image. Or you can email the pics to me and I can post it for you. Your choice.
Copied from a post from Gary 69Z28-RS
To meet the image size requirements, I suggest first using the standard PAINT program to clip out just the portion of the image you desire, and then use a program such as Light Image Resizer to reduce the data volume (with little loss of information). This program is free for personal use and is very flexible to you can tailor it (to achieve the results required)...
The newest forum software includes a function that will automatically resize the pictures for you.
Still best to crop the picture to highlight what you want to show. ;)
Is there a way to send a photo via PM?
No, I had looked into it while I was setting up the new forum.
To clarify, posting pictures is still not available in the Quick Reply box.
Click either Reply or Preview. You'll see "Click or drag files here to attach them." as shown in the picture below.
