Kind of in a bind here I put a 454 in my 69 with a Weiand stealth intake Eldlebrock carb and im thinking its way too tall to use the reproduction cowl induction kit. What intake do I need to make this work? I measured the intake and its about 5 1/2 inches from the deck, and the top of the carb is just about level with the cowl, and Im using an aftermarket 2 inch cowl hood. Please help!!
Sounds like you have two main choices to me. Get a shorter intake, or a taller aftermarket cowl hood. Other choices are possible, but expensive (like lower the engine).
A much easier solution is to modify the cowl's air cleaner base. From memory, I took either 5/8" or 7/8" of and re-attached the seal-flange.
My GM hood closes against the seal no problem, and I have small block frame mounts and a Victor Jnr. ;)
(I milled the Vic Jnr's carb flange the factory 4° like OE as they are "square" out of the box)
*** Steve, the picture link tried to run a script file - not good. I removed the link and attached the pic.****
*** Kurt
