I am quite sure that this may have been asked before, however, I had no luck searching for definitive answer. I am trying to find out the rear frame rail spacing on a first generation Camaro. The measurement I need verification on is the "K" dimension shown in the Fisher Body manual. This measurement is taken between the inboard edges of the rear frame rails at the centerline of the rear shackle bolt hole. The Fisher Body manual is showing 42 7/8". I have found some information that stated that the Fisher Body manual is incorrect and the actual measurement is 43 7/8. My project car has a dented and rusted frame rail, so I could not accurately verify this measurement. Any assistance would be greatly appreciated.
Dave
Dave, there are quite a few guys doing complete body rebuilds - some with very long threads going describing them in great detail (along with exchanges of lots of measurements involving the framerails and wheel tubs etc) over on the Team Camaro site / forums / body shop - check it out...
http://www.camaros.net/forums/forumdisplay.php?f=12
Randy
Dave,
K = 43 7/8" at this website... http://1stgencamaro.net/frame.htm
Thanks for the responses. I still do not know what measurement is correct. There has to be someone on this site that has some first hand knowledge of the correct measurement. Hopefully they will read this post and let me know.
Quote from: 1968RSZ28 on February 08, 2011, 12:43:22 AM
Dave,
There are a few measurements on that website that are different to the Fisher body manual?
Dave,
If you are still concerned about this dimension, I will happily measure my 67 for you, as they are the original rails - advise please.
I would appreciate the measurement.
My 67 measures 43 and 15/16 wide, so I would assume the 43 and 7/8 would be a correct measurement. The measurement was taken inside the rails, just below centerline of the shackle bushing mount areas.
67 RS Ragtop - thanks for taking the time to get the measurement for me. Since I first posted the question, I have been able to take measurements from 2 cars. Of course, each one was different. If anyone has a free moment and could measure the frame rail spacing, it would be appreciated. If I had a few more verified measurements, it would help.
Dave
Dave,
For whatever it is worth, I took several measurements. The rear springs and tank are out of my 69 pace car. Measuring inboard edge to inboard edge, using a stanley fatmax tape measure with bushings and a bolt in place to get the centerline, I came up with 42 1/2". Went right to left, left to right, several times to eliminate any possible error on my part. I also did this on my 69 x22 coupe drag car, which still has factory rails, but has coil overs and a fuel cell in the trunk. I came up with 42 9/16". Both cars have the original rails. Hope this helps.
Chris
Chris,
Thanks for the reply. I appreciate it.
Dave
