I would like to try and get a 5-speed from a donor car. I hear all this info about WC and NWC tremec transmissions. What does that mean. Also, what donor cars should I look for to get a good 5 speed tremec manual transmission that will hold up with a 500hp motor?
Thanks.
None of the factory-installed Tremecs (except the T56 in the Viper) will survive behind a 500hp motor; you'll need a T56 or a TKO600 like Keisler Engineering offers.
Check this out! www.5speedtransmissions.com/index.html Click on the 5 speed section on the left and select GM TKO package. By the time you break a couple of Muncies this will seem not so unreasonable. Also study the comparison to the Richmonds. I've personally seen a couple of these things in action. That TKO 600 is impressive and also has a couple of options for overdrive ratio. Dave
Jamie Passion is creating a new Muncie 5-speed so please contact them.
And there is a new MOPAR A833 5-speed out now that you might find interesting.
And A833's came stock in some of our mid '80's trucks.
I want to say that these are both 800 T trannys!
pdq67
