Camaro Research Group Discussion => Mild Modifications => Topic started by: rally on November 30, 2010, 06:01:37 PM
Title: 12 Bolt brake line T-Block on 69 Camaro Z28?
Post by: rally on November 30, 2010, 06:01:37 PM
Guys i am stumped here? What did Chevy do on their 69 Camaro 12 brake line T-Block? Did they use this T-Block to connect the brake lines on the 12 bolt? If so where could i purchase one? Thank You
Title: Re: 12 Bolt brake line T-Block on 69 Camaro Z28?
Post by: mark x22 on November 30, 2010, 06:27:04 PM
its built into the hose
Post by: bertfam on November 30, 2010, 09:22:49 PM
Starting late in the 1968 model year, they went to the intergrated tee built into the line. My 05D (68) has it. I haven't done a lot of research on this, but it appears that late April or early May, 1968 is the changeover date.
Post by: Terry on December 03, 2010, 04:20:43 PM
Search rear drum brake hose for your 69, the block is attached to the hose. you will need a bracket to attach it to the rear.
Post by: 1968RSZ28 on December 03, 2010, 06:14:44 PM
Here's what you need...
http://www.heartbeatcity.com/store/product/12249/Camaro-Brake-hose--rear-drum-brakes--69/
http://www.heartbeatcity.com/store/product/12252/Camaro-Rear-brake-hose-bracket--all--69/
