Any trick to removing the cam lobe under the washer pump? Service manual says it is press fit. I want to use the early design washer pump on my 68 wiper motor but it has the plastic cam lobe (which is slightly larger) and I picked up a early set up with the steel cam lobe. I am trying to avoid breaking it
Never mind, got it off
