Camaro Research Group Discussion => Originality => Topic started by: SSMUNDY on November 17, 2010, 10:29:07 PM
Title: 67-68 front disc brake low pressure switch
Post by: SSMUNDY on November 17, 2010, 10:29:07 PM
Can anyone tell me what is correct for a 1967 Camaro with power front disc brakes. I am refering specifically to the splitter block that has the low pressure switch. I have seen them for sale in both brass and cast iron. The cast iron one I bought new online has a drip that I cannot fix. I am going to replace the block and want to get the correct one.
Sean
Title: Re: 67-68 front disc brake low pressure switch
Post by: BlackoutSteve on November 18, 2010, 01:36:14 AM
OE = cast iron.
An original used one should be an easy find on eBay..
I bought 2 new repro Rear Brake Line Pressure Regulator Valves and both were faulty from poor casting and or machining. Both had leaks impossible to fix. They sent me a free replacement (a 3rd) and it still has a drip..  ::)
See the bubbles at the thread root? (http://img168.imageshack.us/img168/7240/leakybrakevalve005.th.jpg) (http://img168.imageshack.us/my.php?image=leakybrakevalve005.jpg)
Drove me absolutely mad until I figured my flares were good and not at fault.
Just saying.. Try to buy an OE distribution block if you can. ;)
Post by: SSMUNDY on November 18, 2010, 11:10:24 AM
Yeah, I replaced the line twice, with no luck. It was only a drip, and the brakes work fine, but it leaks onto the frame, and that's just not acceptable. I'm a machinist by trade, and I see a lot of crappy machine work done on reproduction parts. I guess I will try to find a good used one instead of getting another new(made in china) one.  Thanks for the insite.
