Camaro Research Group Discussion => General Discussion => Topic started by: svtrich on March 06, 2010, 05:34:10 PM
Title: what intake gasket for a 69 Z? with or with out heatriser hole
Post by: svtrich on March 06, 2010, 05:34:10 PM
Im ready to put the manifold on. should I buy a gasket that has no heatriser provisions.I live in California so a choke wont be an issuse.which gasket shold I use?
                     Richard
Title: Re: what intake gasket for a 69 Z? with or with out heatriser hole
Post by: 68Zproject on March 06, 2010, 06:03:06 PM
I blocked mine off and live in Oregon.  I haven't had any issues.  It does take a while to warm up when it's cold.
Post by: svtrich on March 06, 2010, 06:05:48 PM
do you remember what gasket  you used
              Rich
Post by: Gramps69Z on March 06, 2010, 06:12:54 PM
Previous posts using the advanced search function.
http://www.camaros.org/forum/index.php?topic=6098.0
Post by: svtrich on March 06, 2010, 06:38:43 PM
that doesnt tell me what gasket I should use
Post by: 68Zproject on March 06, 2010, 10:14:43 PM
I used Fel-Pro. The gaskets I had have a little metal piece that goes in the hole to block it off.  Same gasket, you either used the metal block or not.
Post by: RamAirDave on March 06, 2010, 10:50:22 PM
Fel-Pro also has a black "racing" gasket set that has no holes for the heat crossover.  Don't remember the pn, but it's one off from the blue set.
Post by: JohnZ on March 07, 2010, 10:39:36 AM
It's a lot easier to reverse if you just wire the heat riser valve open, and the choke will still work.
Post by: svtrich on March 07, 2010, 11:11:50 AM
John
do you know a fel pro part # that you can recommend?
                    Richard
Post by: JohnZ on March 08, 2010, 12:31:13 PM
Quote from: svtrich on March 07, 2010, 11:11:50 AM
John
                    Richard
I use Fel-Pro #1256 - has stainless inserts with small round holes at the crossover passage instead of the full open ports.
Post by: NED on March 10, 2010, 10:38:28 PM
Paragon Corvette reproduction parts has the correct gasket set for the 69Z. Same as Corvette with aluminum intake.   Clem
