Camaro Research Group Discussion => Decoding/Numbers => Topic started by: alex68rs on January 30, 2010, 05:10:39 PM
Title: 68 Venezuelan Camaro
Post by: alex68rs on January 30, 2010, 05:10:39 PM
Hi
I've got a 1968 camaro Vin # 12437HC108713, TR 724, Paint 697-123.
I know that the car was assemble in caracas and comes with red standard interior. But thats the only thing I know about it. Can someone can tell me what is that paint code? PPG code or dupont code?. Where I can find info on my original option( engine, trans, drivetrain)
thanks at advance!
Title: Re: 68 Venezuelan Camaro
Post by: 1968RSZ28 on January 30, 2010, 08:15:11 PM
Hi & Welcome -
Congratulations!  Caracas Camaros are very rare.  Have you read these CRG threads?
http://www.camaros.org/forum/index.php?topic=5786.0
http://www.camaros.org/forum/index.php?topic=5070.0
How original is the car?  Can you please post some photos of your car?
KurtS,( http://www.camaros.org/forum/index.php?action=profile;u=3 ) is the guru on the Caracas Camaros.
Post by: KurtS on January 30, 2010, 11:40:07 PM
Alex,
697-123 is possibly a Dupont number. But normally they are longer and with different first 3 numbers, like 926-96908. I've only seen one other Caracas car that had that style of paint code. The others had either 8 or 9 digits.
Is the engine, transmission, or axle original? I'm guessing the engine and trans are not -  http://www.camaros.net/forums/showthread.php?p=1246548#post1246548
http://www.camaros.org/drivetrain.shtml shows where the axle code is stamped if it is original.
Post by: alex68rs on January 31, 2010, 08:35:15 PM
Hi
This is not the original motor and trans. but the rear end I think it is original, I'll check it out this week. I looked on many paint sites including dupont and no ones had this code in there list. Did the other car with the same code style found his original color? With the inerior red, what combinaisons is possible? black on red...white on red.. ??
Post by: alex68rs on January 31, 2010, 08:38:53 PM
There's 2 photos that I took when I bought it in 2008..
Post by: KurtS on February 01, 2010, 12:19:36 AM
The other car was coded 697-102.
If you pull up the scuff plates and lift up the carpet, you'll probably be able to see the original color. Also, look up in the underside of the trunk, that normally has some paint left too.
Post by: alex68rs on February 01, 2010, 06:36:05 PM
Is that normal for venezuela car to have no sides markers at the back??
Post by: alex68rs on February 06, 2010, 07:19:38 PM
I have the original rear end! casting date:E168. an originaly have a 2.73 gear but now it is a 3.08. I found my original exterior paint. I know it was red, just like the interior. Did they have many variation of the color or it's only the matador red paint.
Post by: 1968RSZ28 on February 06, 2010, 08:09:54 PM
What's the rear axle code?  The rear axle code stamp location is shown at the following link...  http://www.camaros.org/drivetrain.shtml#axle
Post by: alex68rs on February 07, 2010, 11:29:16 AM
 the axle code is: BP 0523G2
the casting date is : E168
What the ''NF'' means after the 10 bolt code: 3894859 NF
Post by: KurtS on February 07, 2010, 06:25:35 PM
The only normally available red in 68 was Matador Red. You'd have to have a sample to compare or have your paint color scanned to see if it was a match or not.
Post by: alex68rs on April 29, 2010, 05:06:47 PM
Hi
does somebody know something about that console, it is on my '68 Caracas camaro. why it have a little square and two hole. it is on the left side on the console
thanks
