Camaro Research Group Discussion => Maintenance => Topic started by: stovebolt on January 11, 2010, 11:09:58 AM
Title: 1968 Monoleaf Rear Spring Front Bushing
Post by: stovebolt on January 11, 2010, 11:09:58 AM
Two questions: when the monoleaf rear springs were available from GM, did they come with the front bushing installed or was the bushing sold seperately? Also, has anyone installed the Perfect Circle front bushing. How is the quality, would you recommend them? Thanks, Joe.
Title: Re: 1968 Monoleaf Rear Spring Front Bushing
Post by: Indy 69 on January 11, 2010, 01:47:20 PM
Joe,
The Perfect Circle bushings are fine from my experience with them. Also, they are available from Moog and TRW if you need others to look at.
I do not know about the springs being supplied with the bushing already installed, I am sure someone here will have the answer for you..   ;)
Post by: stovebolt on January 12, 2010, 10:16:43 AM
Does anyone know the TRW or Moog part number for this bushing? Thanks.
Post by: JohnZ on January 12, 2010, 10:19:25 AM
Quote from: Indy 69 on January 11, 2010, 01:47:20 PMI do not know about the springs being supplied with the bushing already installed, I am sure someone here will have the answer for you..   ;)
The monoleaf springs came with the front bushing already installed by the spring supplier; the rear shackle bushings were separate, installed at the car assembly plant.
Post by: Indy 69 on January 12, 2010, 03:27:22 PM
Quote from: stovebolt on January 12, 2010, 10:16:43 AM
From memory the 2 companies have the same part# B298.
Post by: stovebolt on January 13, 2010, 08:56:05 AM
Thanks to all for your help. Joe.
