Camaro Research Group Discussion => General Discussion => Topic started by: DONCZ28 on December 02, 2009, 11:34:31 PM
Title: 69 FACTORY ROTORS
Post by: DONCZ28 on December 02, 2009, 11:34:31 PM
DOES ANY ONE HAVE A PIX  OF AN ORIGINAL 69 FRONT ROTOR.   MY ROTORS HAVE  VARIOUS SIZE HOLES IN THE HUB (OUTSIDE DIAMETER)  NEXT TO THE DISC......I HAVE OWNED THE CAR SINCE 1982......DON....
Title: Re: 69 FACTORY ROTORS
Post by: Jerry@CHP on December 03, 2009, 09:15:46 AM
That was for balancing,
Jerry
Post by: DONCZ28 on December 03, 2009, 05:35:53 PM
     JERRY, I HAVE SEEN PICTURES OF REPO'S, THAT CLAIM TO BE MADE FROM AN NOS PART, BUT I DO NOT SEE ANY BALANCE HOLES DRILLED.   DO MOST FACTORY ROTORS HAVE THESE HOLES?  ARE THE REPO'S NOT BALANCED? WAS THE SERVICE PART FROM GM UN BALANCED?........DON
Post by: Dusk Blue Z on December 03, 2009, 07:09:38 PM
I have both the original rotors on my car, only one has the holes drilled to balance the rotor. I am sure there was a balance spec for the rotors when new, if they were within tolerance no additional machining was needed. Attached is a picture of the paint mark that was only on the rotor without the holes.
