Camaro Research Group Discussion => Restoration => Topic started by: GSD5 on October 18, 2009, 10:10:13 AM
Title: 67 Kick Panel Vents
Post by: GSD5 on October 18, 2009, 10:10:13 AM
Does anyone know if it is possible to replace the rod that activates the vent in the kick panel (non-AC car) of a '67? If so, any suggestions on the procedure would be greatly appreciated! I found a set of otherwise excellent originals to replace the beat up ones that I have now but one of the rods is broken off at the point where it starts to extend into the recessed area that the handle is in. There is a metal clip on the back side that seems to resiist removal, and I'm afraid that forcing it will cause the plastic to snap.
Thanks!
Title: Re: 67 Kick Panel Vents
Post by: Sauron327 on October 18, 2009, 02:37:56 PM
Piece of cake. Pull that clip and remove the assembly. Spray a little help on it if you have to; I never did. They are snug and seem a worthy adversary. You will find the loop at the end of the cable will require persuasion to pass through the hole. I've done a few. Kicks are pretty resiliant to "snapping" as you say but use caution nonetheless. Lube that sleeve assy well.
Post by: GSD5 on October 18, 2009, 03:20:47 PM
Thanks...I'll give it a whack, and thanks also for the comprehensive nature of the info!
