Camaro Research Group Discussion => Maintenance => Topic started by: sixt9x33rs on September 11, 2009, 05:45:27 AM
Title: 69 z manual steering gasket cover install
Post by: sixt9x33rs on September 11, 2009, 05:45:27 AM
Can someone give me a few tips about the install of the above gasket? Is there more to it than removing the three screws that hold the cover on? I am a bit inimidated by the center adjusting screw.
Title: Re: 69 z manual steering gasket cover install
Post by: m22mike on September 11, 2009, 07:09:06 AM
The adjusting bolt is threaded to the cap. You will need to  "un screw" the cover by turning the adjuster. Go easy and do not beat on it with a hammer, you may need to loosed the cap with a very this putty knife if the old gasket is stuck.
Re adjust box when done.
Good luck Mike
Post by: sixt9x33rs on September 11, 2009, 10:19:09 AM
Quote from: m22mike on September 11, 2009, 07:09:06 AM
Good luck Mike
How do you re adjust the box? Would this procedure be loacted in the Chasis Service manual?
Post by: 1968RSZ28 on September 11, 2009, 12:12:55 PM
Quote from: sixt9x33rs on September 11, 2009, 10:19:09 AM
Yes, see Section 9 in the '69 Chassis Service Manual.
Post by: sixt9x33rs on September 11, 2009, 05:30:21 PM
thank you
