Anybody come up with the perfect solution to water leakage aroung 69 tail light gaskets?? I have heard that aftermarket gaskets are really bad. And mine are definitely leaking.
I'm thinking about re-using the original gaskets and running a bead of Black silicone RTV around both sides.... Any thoughts / opinions?
Obvious question but have to ask it. Have you tightened down the lights to the car recently?
Not lately, but I will check that.
Thanks.
Seal between the gasket and lens, not between the gasket and body.
Quote from: GaryL on September 07, 2009, 11:13:09 AM
Will do.
Thanks.
