Camaro Research Group Discussion => Decoding/Numbers => Topic started by: airart1 on August 28, 2009, 10:58:48 AM
Title: VIN Number Help
Post by: airart1 on August 28, 2009, 10:58:48 AM
Can you help me decode the following VIN Number?
12437KC100126
Title: Re: VIN Number Help
Post by: Oregonjam on August 28, 2009, 09:53:00 PM
That appears to not be a valid VIN for any vehicle I have ever seen.
Can you post a photo and make/model it is on. It is not a GM VIN I am familiar with at all.
A VIN when decoded for a 1st gen Camaro will only tell you the following
6 or 8 cylinder, Coupe or Convert, year of manufacture, Assembly plant, and serial number
The trim Tag would help you decode factory installed options...
Post by: JohnZ on August 28, 2009, 10:07:12 PM
Quote from: airart1 on August 28, 2009, 10:58:48 AM
12437KC100126
Are you in Venezuela? Can you post a photo of the VIN plate and cowl tag?
Post by: airart1 on August 28, 2009, 10:51:14 PM
This car is in the United States. The speedometer is in kilometers. I am helping a friend research this car. i will get the photos this weekend and post them.
Post by: BlackoutSteve on August 29, 2009, 01:11:12 AM
Pictures of the speedo too please!
Post by: airart1 on August 29, 2009, 09:31:52 AM
I cannot get the pictures to load in this format. Please go to - www.drop.io/69RSCamaro - to view the pictures of the cowl tag and the speedometer.
Post by: airart1 on August 29, 2009, 12:43:02 PM
I had the owner look at the VIN number and it is the same as the cowl tag.
Post by: BlackoutSteve on August 29, 2009, 05:39:35 PM
Just one pic shows, and that's of the tag.. Gee, I never seen one like that before..
Post by: airart1 on August 29, 2009, 05:53:13 PM
I reposted the picture of speedometer at www.drop.io/69rscamaro.
Post by: JohnZ on August 29, 2009, 08:21:27 PM
Quote from: airart1 on August 29, 2009, 12:43:02 PM
Can you post a photo of the VIN plate so we have both it and the cowl tag? The car may have been built in Venezuela, and the VIN plate could verify that.
Post by: airart1 on August 29, 2009, 08:57:45 PM
He says that the VIN number and the Cowl tag have the same number. We are also thinking that it is from Venezuela. Is taht what the KC means?
Post by: 1968RSZ28 on August 29, 2009, 11:49:13 PM
12437KC100126
12437 is the body type = Coupe
K is the year = 1970
C is the assembly plant = Caracas (Venezuela)
100126 is the sequence number
A rare car indeed!  Does the car have it's original engine?  If yes, can you post a picture of the engine pad?
Post by: airart1 on August 30, 2009, 12:01:36 AM
I believe that this car is a 69. Does the K still stand for 1970. Where did you find this info on KC? There a lot of folks on the net looking for this kind of info. I saw another post in another forum and they had a JC code.
Post by: airart1 on August 30, 2009, 02:05:53 PM
I have verified that the engine numbers match. I have posted more pictures at www.drop.io/69rscamaro
We will get the cowl vent removed shortly and take alook for any other stampings there. If I am guessing right, the K is for the 10th month which makes this car one of the late 1969's produced due to the extened production schedule while they were fixing the metal stamping problems on the 1970 cars. Any or help or questions would be appreciated.
Post by: 1968RSZ28 on August 30, 2009, 11:56:34 PM
Quote from: airart1 on August 30, 2009, 12:01:36 AM
Correct me if I'm wrong, but isn't the year code on the first generation Caracas Camaros is as follows...
G = 1967
H = 1968
J = 1969
K = 1970
The letter "I" was not used because of it's similarity to the number "1".
The person on this forum who could tell you the most about the Caracas Camaros is "KurtS".
Post by: 1968RSZ28 on August 31, 2009, 12:25:37 AM
I just found an email about this car in my spam box.  I'm glad the partial VIN (1KC100126) on the engine pad matches the car's VIN.  The "1" before the "KC" stands for Chevrolet.  What's the engine assembly code?  The engine assembly code is also on the engine pad to the right of the partial VIN.  The engine assembly code (if original) can help date the car.  As for your question about the cowl tag, "718" is the car's interior trim code = red standard interior with front bucket seats.  Is this the interior in the car?  I can't make out the number to the right of the trim code in your photo, is it 928-50521?
