Camaro Research Group Discussion => Originality => Topic started by: 68Zproject on June 22, 2009, 01:18:43 AM
Title: 68 Grill nuts and bolts
Post by: 68Zproject on June 22, 2009, 01:18:43 AM
I'm having a little trouble getting some original type nuts and bolts to attach the grill and mouldings to the front of my 68 Z. I'm showing a part # for the lower trim nuts in AMK's catalog as a machine threaded stamped nut.  Is this correct?  These look similar to the nuts that hold on emblems etc.  I can't tell for sure in the AIM what they look like and wondered if they were these stamped nuts and not a regular nut.
I also don't show an AMK # for the screws or nuts that hold the lower part of the grill to the valance.  The AIM part #'s are 9919303 for the screw and 3846854 for the nuts.  Anyone know what these are in AMK or can tell me the size and kind of nuts and bolts that were original?  Thanks.
PS Anyone know if the screws that hold the headlight bezels on were painted or dark phosphate?
Title: Re: 68 Grill nuts and bolts
Post by: x77-69z28 on June 22, 2009, 10:21:29 AM
the originals are aluminum rivets.
Post by: 68Zproject on June 22, 2009, 10:36:13 AM
Non RS.
Post by: 68Zproject on June 23, 2009, 11:45:25 AM
I was hoping to have this back together for a car show this weekend.  If anyone has any original bolts that they could look at or any knowledge of what they were I would really appreciate it.
Post by: x77-69z28 on June 23, 2009, 08:17:41 PM
check your inbox.
Post by: 68Zproject on June 24, 2009, 03:17:42 PM
Anyone with an untouched std grill that could check or knows what the size, type and headmark of the bolt or screw  and the nuts for attaching the bottom of the grill to the valance?
Post by: 68Zproject on June 28, 2009, 11:11:30 AM
Post by: Pex68 on July 07, 2009, 01:25:06 PM
Just wanted to link to the other thread so people can follow since we got into this discussion over there too! :)
http://www.camaros.org/forum/index.php?topic=5528.0
Post by: 68Zproject on July 15, 2009, 12:14:57 PM
Still searching.
Post by: 1968 Z28 on July 16, 2009, 03:10:13 PM
Well......I looked at my original grille hardware and the closet I can come to AMK is this.
     B-12081 Screw....Looks nearly the same as my original,  same dimensions, black phosphate, except my original has 3 bars inside the head.
     B-12250 Spring Nut ....Similar to my original, my original looks like a (U) nut, that is the (bent) and (flat) part of the nut are the same length......... whereas the AMK nut looks more like a (J) nut, the (flat) part of the nut is shorter than the (bent) part.
My car is a 68Z, 07C, NOR
Hope this helps you,
Jerry G.
Post by: 68Zproject on July 16, 2009, 03:48:43 PM
Quote from: Sonet on July 16, 2009, 03:10:13 PM
Are you saying yours was not a hex nut like the AIM shows?  Pex 68 said his was riveted.  There is a resto shop near here and they said one of theirs was put on with the spring clips too.  I also may have some info from TC soon.  I'm trying to get some pattern of how things were attached and it may change with dates.
Yes, very much so.  Thanks again.
Jerry G.
Post by: 1968 Z28 on July 16, 2009, 03:54:08 PM
Yep......no hex nut like the AIM shows..... just spring nuts and pointed hex head screws.
Post by: 1968 Z28 on July 16, 2009, 11:14:35 PM
Little more info.......
I found the #9419303 screws referenced here....not for the Camaro grille but they look the same.
     http://www.paragonreproductions.com/p-350282-heater-box-y-duct-screw-kit.aspx
I found the #3846854 nuts referenced here.....not for the Camaro grille but they look close.  The set of 8 nuts are the ones that look similar to my originals.
     http://www.paragonreproductions.com/p-356156-front-grille-attaching-kit.aspx
Later.......
Post by: 68Zproject on August 01, 2009, 02:50:54 PM
(http://i174.photobucket.com/albums/w112/68zproject/IMG_0002.jpg)
Sonet, Does your original clip look like places A and C and just needs to be longer at B on this AMK clip?
Post by: 1968 Z28 on August 01, 2009, 10:23:41 PM
Here is a picture of my original U-Nuts with some measurements I made....
Post by: 1968 Z28 on August 01, 2009, 10:36:36 PM
Check out this Link from Mr. G's Fasteners and look at # FA681 that is on page 75....http://www.mrgusa.com/pdfs/74-77unut.pdf.
This one is fairly close
Post by: 68Zproject on August 02, 2009, 10:58:04 AM
Thanks again Jerry.  I thought I found another place that the # was used for, but it was the 9419303, not the 9919303.  The 9419303 is used to hold the ends of the grill to the valance on the RS.  Well, at least according to the AIM and it shows it to be a screw.  Until someone can tell me their car had nuts like the AIM shows, I'm going to figure that was just one of those things that wasn't.
Post by: 68Zproject on August 03, 2009, 02:04:29 AM
I found another place where the 3846854 nut was used.  It's the A/C ambient temp switch mounting nut.  C60-E1 item 13 in the AIM.  In this picture it looks more like a u-nut than a hex nut.  In fact, there's no way that could be a hex nut.  Maybe the picture for the grill was just a bad representative of what that item is.  Got me way off the path thinking it was a hex nut.  Thanks again for all your help guys.
Post by: 1968 Z28 on August 03, 2009, 06:16:04 AM
Yup.....Lazy artist......LOL!
