I have a oil leak via my fuel pump on my '69 camaro. I was going to do this job myself (first timer) and possibly replace the entire fule pump?? Mechanic wants 172.00 for the entire fix!
Any thoughts as to replacing the pump?
Any special do-not's or any special upgrade in fuel pump advice would be appreciated.
thanks again,
Nick p.
Do run the bolt in that holds the pin from the cam in place. Do not forget to back it out when your done. get a book with pics,and use a line wrench. It's not too hard.
First, make sure you know where the oil is really coming from; I see lots of cars that don't have the bolt in the top front boss right around the corner from the fuel pump on the front of the block, and leakage from there coats the fuel pump. If that bolt is missing, it takes a 3/8"-16 x 1/2" bolt with thread sealer on it.
Okay..thanks for the advice on the fuel pump JohnZ and Gibster.
The screen shot helps and the pump is exactly what mine is.
also sometimes oil can leak out of the vent holes that are in the fuel pump itself-(sometimes gas also can leak out of these holes(of course the pump is bad)--also on the fuel pump rod you can use and old hacksaw blade to hold it up or on a cold engine grease will help hold it also
