I took my metering valve off the car, soaked it in Evap or rust rinsed it out with water then blew it out with compressed can air then dried it thoroughly with a blow dryer. Is there anyway that I can look at the pipe inlets and see if I have messed something up? Or should I squirt something in the metering valve to keep it lubed up?
I'd take it apart, clean everything properly, lube all the parts with brake fluid, and re-assemble it.
Quote from: JohnZ on February 19, 2009, 11:16:10 AM
Thanks John.
I did the same on the proportioning vlave under the master cyclinder. I did not see an easy way to take that apart. Your thoughts?
Lawrence
Quote from: sixt9x33rs on February 19, 2009, 11:45:51 AM
Thanks John.
Lawrence
The only proportioning valve is down on the subframe below the driver's door. The other device below the master cylinder (besides the round metering valve) is the distribution block, which has no valving function at all - it only contains the differential pressure warning switch.
Quote from: JohnZ on February 20, 2009, 01:37:17 PM
That is the part I am talking about. The block with the pressure warning switch. Is that part also known as the brake manifold?
Should I clean that any special way?
Thanks John.
Lawrence
Quote from: sixt9x33rs on February 20, 2009, 03:35:58 PMThat is the part I am talking about. The block with the pressure warning switch. Is that part also known as the brake manifold?
I suppose you could call it the "brake manifold", but it's correctly described as the "distribution block"; I've never found it necessary to do anything to it, as it has no valving function.
