I have searched the forum for the answer to this, but no luck... thanks for your help!
2 bolt.
2-bolt with windage tray.
Jerry
As a general rule, no '68 small-blocks had 4-bolt caps, 302 or otherwise. The 4-bolt blocks didn't appear until 1969. Hope this helps.
OK I'm still learning. What is MO?
MO would be the engine code stamped on the block for 67 and 68 302's.
Quote from: WYKOFF69Z on February 03, 2009, 04:13:13 PM
In
1967 "MO" was the engine application suffix code for 302s without smog. ;)
In 1968 all 302s where stamped "MO".
MP would be for smog on 67's.
Thanks Paul,
