Camaro Research Group Discussion => Originality => Topic started by: firstgenaddict on January 05, 2009, 01:19:28 AM
Title: 69 12 bolt Eaton Rear Axle Assemblies
Post by: firstgenaddict on January 05, 2009, 01:19:28 AM
How complete were the Eaton 12 bolt rears when they arrived at Norwood?
Were they Drum to Drum assemblies minus the brake tubing and springs?
Title: Re: 69 12 bolt Eaton Rear Axle Assemblies
Post by: JohnZ on January 05, 2009, 04:21:32 PM
Quote from: firstgenaddict on January 05, 2009, 01:19:28 AM
Yes, that's correct - the brake pipes, block, flex hose, springs, parking brake cable brackets and lube were added at Norwood; the parking brake cables were part of the axle assembly as received.
