Camaro Research Group Discussion => Originality => Topic started by: nuch_ss396 on March 02, 2006, 12:42:29 PM
Title: Correct finish(es) on 69 12-bolt Camaro rear
Post by: nuch_ss396 on March 02, 2006, 12:42:29 PM
Several weeks ago, there was a thread here on the CRG about painting the rear correctly in the 1969 Camaro.  I can't seem to find that
thread, so I will ask a question which I don't think was addressed anyway.
It appears that the rear assembly was painted black.  I believe JohnZ pointed this out clearly.  My question concerns the corrent finish
on the axle flanges.  Would these be cast iron in color ( natural ) or black also?  For the sake of clarity, axle flange refer to the plate at
the end of the axle onto which the brake drum & wheel are mounted.  Also, what about the correct finish on the yoke assembly that
mounts to the pinion gear.  Would this be natural cast iron as well, or black?   ???
I am having my rear restored as I write this and I forgot to get this information earlier.  ::)
Title: Re: Correct finish(es) on 69 12-bolt Camaro rear
Post by: william on March 02, 2006, 01:49:58 PM
Drums were painted black with the axle. Several vintage magazines have photos that clearly show this. Hot Rod did a road test and subsequent mods to a '69 Z/28. The photos of the T-bar installation show the drums were black.
Post by: nuch_ss396 on March 02, 2006, 02:37:26 PM
William,
So, would the drums have been installed on the rear for painting,
or painted as a separate process?  In addition, how would the
black painting process for the rear extend to the axle flanges?
In other words, if the brake backing plates and axles were installed,
then the whole assembly painted, would the black just overspray
the axle flanges, or were they liberally coated?
It's these details that always get you......  ::)
Post by: william on March 02, 2006, 08:10:12 PM
The March '68 Hi-Perf Cars has a feature on a B-M 427 Camaro with probably the best one. The drum is clearly all black as is the center of the axle flange. The single retaining clip on one of the studs is visible and obviously not painted.
The May '68 Rodder & Super Stock has a smaller, similar photo of a '67 that shows essentially the same thing.
May '68 Super Street Cars shows a drum with little more than overspray on the face. The circumference appears to be thoroughly painted.
The May '69 Hot Rod shows the same as above. The angle is better and slight overspray can be seen on the axle flange.
It is not possible to determine if the studs on any of these were painted. It would have been simple to mask them.
Post by: JohnZ on March 03, 2006, 10:07:30 AM
The axle SHAFT itself wasn't painted; the complete axle ASSEMBLY was painted after the drums were installed, as the last operation before the axle was placed in the shipping rack. I don't recall ever seeing any protetctive sleeves on the lug studs, but they avoided painting the pinion flange where the U-joint attached.
Post by: nuch_ss396 on March 03, 2006, 09:30:05 PM
John,
A couple of additional questions for you.
To "properly" restore my 12-bolt rear, should I put the brake drums on, mask the wheel mounting studs, then paint it all black?
What about the axle flange itself?  Should I remove the brake drum and paint it black all over ( inner & outer surfaces )?
Since you mentioned the pinion yolk, should this be a cast iron ( natural ) color?  BTW, was that yoke installed after it was
put in the car?  There is a reason for this question.  I am currently trying to source the correct THM400 driveshaft for my
69 L/78 Camaro.  My research has shown that possibly two different u-joints were used.  The standard sized one for all
driveshafts less the THM400, which used a larger u-joint.  If this is true, then the pinion yolk would have have to be
different to accomodate this larger u-joint.  It would only stand to reason that it was later installed, and then possibly be
natural in color.
Do you remember two different pinion yolks as described above?  ???
Post by: JohnZ on March 04, 2006, 10:47:56 AM
As I posted above, the axle SHAFT wasn't painted at all; put the drums on, mask the studs, and paint the entire assembly. The pinion flange was installed at the axle plant, generally didn't get paint on it, and wasn't touched at the car assembly plant except to attach the prop shaft rear U-joint.
Post by: william on March 05, 2006, 10:52:32 AM
The 12-bolt pinion flange was redesigned for '69. The new design used retaining straps rather than the 67-68 u-bolt & nut and was larger, the reason driveshaft length changed. All 69 12-bolt axles used the same flange.
Don't forget the axle code labels the factory pasted on one or both brake drums, seen on page 166 of Jerry's excellent 1969 Camaro book.
Post by: RamAirDave on March 08, 2006, 12:36:12 AM
My "over-restored" example:
(http://i20.photobucket.com/albums/b217/RamAirDave/GoldZ/100_0415.jpg)
I know, grey drums and incorrect vent  ;)
dave
Post by: Tinkerr on March 08, 2006, 02:32:09 AM
My 68 BB turbo 400 12 bolt has the large flange and straps.I was of the mind that 10 bolts used the u bolt design and 12 bolts used the straps.I've also read that BB and heavy- duty applications recieved the strap design.Small block 12 bolts got u bolts,although I would expect the Z's to have the strap style.I would think they would qualify as heavy-duty.
Until several weeks ago I wasn't aware there were two different 12 bolt pinion flanges.I had a driveshaft that was supposed to be for a turbo 400 Camaro,but when I attempted to attach it to the 12 bolt imagine my suprise when it didn't work,it was then I found my 12 bolt has the big flange.
Post by: william on March 08, 2006, 01:05:52 PM
Actually Dave I doubt they looked that good!
Post by: nuch_ss396 on March 09, 2006, 10:48:13 PM
Quote from: Tinkerr on March 08, 2006, 02:32:09 AM
Tinkerr,
It was always my understanding that the '69 THM400 Camaro's used this big pinion flange.  I just can't seem to
find one right now.  Actually, several people told me that Camaro's all used the small pinion flange, but that never
made sense.  I know the THM400 front yoke uses the large u-joints.  So why would the rear u-joint be smaller.
I was also told that the '69 Firebirds used the large pinion flange and that is why some people get the two confused.
(http://webzoom.freewebs.com/nuch_ss396/69%5FTHM400%5Fpinion%2Dflange%5Fcomparison.jpg)
This is a comparison between the standard ( bottom ) and THM400 flange.  Does your pinion flange look like this?
Can I ask a large favor?  Can you take some detailed images of this flange along with some measurements?
See the image for the dimensions I need.
Is there a part number on the pinion flange that I can reference?
Lastly, what is the build date of your car and what exactly was the 396 stock hp designation ( 325hp, 350hp, 375hp )?
Post by: nuch_ss396 on March 09, 2006, 10:59:09 PM
Quote from: RamAirDave on March 08, 2006, 12:36:12 AM
dave
Dave,
I would like to see more images of the complete rear if possible.  I am particularly interested in the wheel cylinders,
the brake drum mounting flanges ( with 5 lugs ), the detail of the brake assemblies, and the brake lines.  BTW, did
you use SS brake lines?
What finish treatment did you apply to the pinion flange and its dust shield?  Or, are they just natural?  They look
good.
Lastly, can you take an image of the one of the brake backing plate mounting bolts?  I need to know if the nut is
facing to drum or the differential.
Post by: RamAirDave on March 10, 2006, 02:28:35 AM
Hey Steve,
The pinion yolk is cast grey, the dust shield is steel (both painted), the straps are natural from AMK (i think, dont seem to be plated), and the strap bolts are dark phosphate plated.  I use OEM steel lines.  The SS look good, but not original.  Plus Ive experienced that the OEM is easier to work with and easier to seal.
Here are the pics of it that I have hosted.  If you need any more pics or info, email me RamAirDave@aol.com and I should be able to help you out.
dave
BTW, its done pretty much factory, but with a Day 2 touch
(http://i20.photobucket.com/albums/b217/RamAirDave/GoldZ/100_0374.jpg)
(http://i20.photobucket.com/albums/b217/RamAirDave/GoldZ/100_0413.jpg)
(http://i20.photobucket.com/albums/b217/RamAirDave/GoldZ/100_1521.jpg)
Before:
(http://i20.photobucket.com/albums/b217/RamAirDave/GoldZ/100_0110.jpg)
Post by: Tinkerr on March 10, 2006, 02:40:32 AM
Steve,
I'll get you a couple pictures over the weekend. Looking in Rick's catalog they list the large u-joints(3 5/8"x 3 5/8") front and rear for 67/68 400's and large rear flange. The 3 1/4" is listed for all 69's regardless of trans. That's not meant to prove or disprove anything just an observation. My car is a 396/325,turbo 400,3:08 r/p non-posi. When I had the new r/p set-up, the mechanic commented on the larger pinion nut, it didn't mean anything to me, but maybe as a after thought, it's related to the large flange.The rear was unmolested until 06.
Post by: 68rsssrag on March 12, 2006, 08:17:40 PM
I have a 1968 12 bolt with posi. Originally the axle carriers and center were not painted. Can this be?
Arno
Post by: nuch_ss396 on March 12, 2006, 10:38:12 PM
I just received these images from CRG member "Tinkerr" and posted them at his request.
Thanks for your assistance Paul ! ;D
THM400 driveshaft ( left ):
(http://webzoom.freewebs.com/nuch_ss396/reply%20pics%20001.jpg)
THM400 driveshaft ( bottom ):
(http://webzoom.freewebs.com/nuch_ss396/reply%20pics%20002.jpg)
(http://webzoom.freewebs.com/nuch_ss396/reply%20pics%20003.jpg)
(http://webzoom.freewebs.com/nuch_ss396/reply%20pics%20004.jpg)
Post by: nuch_ss396 on March 12, 2006, 10:48:08 PM
Paul?
Are the THM400 u-joint end-caps of a slightly larger diameter that the standard ( smaller ) u-joint end-caps?
Is your THM400 driveshaft original?  I'd love to see one of those u-joints in detail.........
Post by: Tinkerr on March 12, 2006, 11:52:52 PM
Steve,
The t/400 u-joint caps are slightly larger outside diameter.I attempted to place a cap from the other u-joint on the t/400 u-joint, it won't fit inside diameter is to small.
Hope this helps
