Camaro Research Group Discussion => Restoration => Topic started by: Brandan on September 22, 2008, 04:22:34 PM
Title: Update to my '67 Butternut Yellow Convert Project......
Post by: Brandan on September 22, 2008, 04:22:34 PM
Here is a link to the site....Slowly started the painting process...I am hopeful maybe two more weeks till I can get it home and start reassembly.  Feedback welcome both good and bad.....
http://www.cardomain.com/ride/2960049 (http://www.cardomain.com/ride/2960049)
Thanks for looking.....
Brandan-
Title: Re: Update to my '67 Butternut Yellow Convert Project......
Post by: heckler on October 16, 2008, 03:01:50 PM
What color primer did you use and why?  I have 67 soft top that will be butternut yellow.
Post by: Brandan on October 17, 2008, 02:17:46 PM
we used two different colors. both epoxy primer.  gray and black.  gray on the outside and black on the inside.  no real reason.  we only por 15 the inside used black on the inside trunk and passenger area.  I think the spatter paint will go over better on the black than the gray.
Post by: heckler on October 18, 2008, 02:52:00 PM
thanks for the info.....wasn't sure if primer color would make yellow pop more.
Finally,  how are you tackling the paint while it's on a rotissorie?  Mine is also on a rotissorie and I'm concerned on when and how to pant under where it's currently mounted.  Advise?
Post by: Brandan on October 23, 2008, 04:50:59 PM
the rotissorie made working on the bottom easy.  we painted the bottom of the car while it was on the rotissorie and the butternut yellow when if was on the ground.  the fenders, hood, trunk, etc.....was all painted off the car individually.  also when we took the car off the rotissorie we painted the parts of the frame that we missed.  no big deal really. hope this helps somewhat
Post by: Brandan on October 23, 2008, 04:51:49 PM
also i added some more pictures to the site tonight.  feedback always welcome
