Camaro Research Group Discussion => Restoration => Topic started by: Brandan on September 03, 2008, 12:11:56 PM
Title: Natural Metal Finish? Paint undercarriage.....???
Post by: Brandan on September 03, 2008, 12:11:56 PM
Looking at Jerry's book, some of the undercarriage calls for "natural metal finish".  Does anybody know of a paint that is natural metal finish?  I don't want to leave some of the steering and springs untreated.....bare metal in Florida is not a good idea..
thanks,
Brandan-
Title: Re: Natural Metal Finish? Paint undercarriage.....???
Post by: Sauron327 on September 03, 2008, 01:16:41 PM
Yes, you can buy "Cast Blast" cast iron gray which is a Seymour paint product. Part #16-048. However, longevity and performance is increased if epoxy primer is used as a substrate.  I personally go the extra step. Your painter can mix the same thing on his system.
Post by: jeff68 on September 04, 2008, 07:12:59 AM
You may want to look into Nyalic clear coat.  It is no longer available directly from Nyalic, but they put me in touch with DoubleHorn Products, who sells it in 4 oz. spray cans under their own name (although I am assured by Nyalic that it IS their product).  It is intended for all types of surfaces, including bare metal or plated surfaces.  Supposedly, this stuff is the best.
I have not used it on the Camaro, but I just used it to clear coat the brake calipers and undercarriage/suspension components on a new car that I just bought.  We'll see how it holds up to a New England winter.
I was worried that this clear coat would be too glossy, but it looks great.  After coating the plated brake calipers on my new car (which have a slightly rough surface texture), you can't even tell they were coated.  On the smooth aluminum diff cover, you can see a slight increase in gloss.
Post by: firstgenaddict on September 05, 2008, 10:11:21 AM
I use Boeshield... it works great for a car driven under 1000 miles a year...
Post by: wtexz10 on September 05, 2008, 06:57:59 PM
I can vouch for Nyalic.  About 5 years ago I coated a freshly bead blasted aluminum intake with it and it still looks good.  I did not know that they no longer sold it direct.
Kris
Post by: Sauron327 on September 05, 2008, 07:47:06 PM
Sorry, Disregard my info. It does not apply to the type of car you are building.
Post by: Brandan on September 06, 2008, 08:51:59 AM
lots of good info here....... thanks.... will have some updated pics of the process soon.
Post by: buenymayor on September 23, 2008, 09:57:17 PM
I used Eastwoods Cast Blast powder coat on all my steering linkage. It looks pretty good, but has a little more sheen than bare cast iron. If you aren't after a points car, I was pretty happy with the results.
Post by: mrdetails on September 24, 2008, 01:42:59 PM
I used Eastwood Diamond clear which comes either gloss or semi-gloss. works good on bare steel or cast.
Good Luck
Post by: Brandan on September 25, 2008, 03:00:51 AM
I went with the Eastwood Spray Gray, for the natural metal finish.  So far so good.  More pictures soon on the site.... unfortuntely the time this is taking is long..... but I think in the end it will be well worth it....I ordered the Eastwood black/aqua for the trunk spatter and it comes with the diamond clear satin so I have my fingers crossed on the correct match and gloss.
they haven't let me down yet.. haha
