good afternoon- would someone please clarify which style temp. sending unit came factory on a 69 350ss camaro ( build date 02/69) with gauges. also which style of connector is correct. pictures if possible. thanks
With gauges, it is the unit with the threaded post. The wire has an eye connector that is attached with a nut.
Dave - would a '68 ss 350 be the same? (no gauges)
Quote from: gro51 on June 18, 2008, 08:22:59 PM
Nope. 68's without gauges used a push-on blade connector on the switch/sending unit for the temperature light.
thanks a lot gentlemen
