Camaro Research Group Discussion => Originality => Topic started by: camaro cat on February 09, 2006, 11:00:24 AM
Title: Date codes on 67 wheels?
Post by: camaro cat on February 09, 2006, 11:00:24 AM
I am looking for some rally wheels for my 67 RS built 10C at LOS. Were wheels always date coded or is there a possability that early wheels weren't? If GM was date coding wheels thru all of the 67 model year any idea when that practice may have started?
Title: Re: Date codes on 67 wheels?
Post by: Farm Boy on February 09, 2006, 11:23:32 AM
The original rally wheels that came with my 11E LOS 67 rs have no date codes. They are 14 X 5 which is correct for a disc brake equipped, non SS, 67. They are stamped DA next to the valve stem.
Post by: camaro cat on February 09, 2006, 11:34:27 AM
Thanks. Your code is what I thought was right for a non SS car. No date codes might make finding a set of 5 easier. Is your car disc brake or power disc brake?
Post by: Farm Boy on February 09, 2006, 02:18:11 PM
My car has manual disc brakes. Here is a picture of a DA wheel with a repo F70-14 tire. These tires are a bit too wide for these skinny wheels. My trim rings and caps are original.
(http://geocities.com/sdampier@sbcglobal.net/Team_Camaro/DA_wheel.jpg)
Post by: JohnZ on February 09, 2006, 03:30:25 PM
'67 wheels were dated, but the dates are stamped on the interior of the rim, under the tire; can't be seen with a tire mounted.
