Camaro Research Group Discussion => General Discussion => Topic started by: big iron on June 05, 2008, 09:46:25 PM
Title: sleeves for power steering hoses
Post by: big iron on June 05, 2008, 09:46:25 PM
Does anyone know if the sleeves for the power steering hoses on first gens. are available  ???
Bob C
Title: Re: sleeves for power steering hoses
Post by: big iron on June 06, 2008, 08:04:03 PM
Up-date
Does anyone have any measurements such as length , I.D. , O.D, thickness of the sleeve, so that I can make some sleeves ?
Post by: gro51 on June 07, 2008, 08:17:41 AM
I've been looking.  Haven't found anyone making them.
Post by: big iron on June 07, 2008, 11:21:01 PM
Joe , thanks for the reply .
I am in the process of building a 67 w/BB and thought I new the correct components for the power steering system .
The 67 assembly manual shows on page 374 ,2 sleeves, 1 clamp and a clip ( part of steering gear ) and on page 370 it only shows the sleeves and the clamp ( no clip ).
The 68 A.M. shows on page 375 the same as 67 A.M. page 374.
The 69 A.M. shows on page 405 2 sleeves, 1 clip, 1 clamp and a clip ( part of steering gear ) .
I bought a very late 68 ss/rs/396 ( in 69 - July or Aug. delivery ) and it had the 69 set up. I am not sure if it had 1 or 2 sleeves.
Also need to know if the return line hose uses screw or pinch type clamps an optional clamp ( 9424894 ) is shown ?
John Z or Jerry do you have any thoughts on this topic ?
Bob C
Post by: JohnZ on June 08, 2008, 10:02:10 AM
The return line ('69) uses a screw clamp; optional part numbers for it simply reflect two different suppliers of similar clamps. Sleeve usages are as shown in the illustrations for the different applications. I don't know of anyone supplying reproduction sleeves.
Post by: big iron on June 08, 2008, 11:15:46 AM
John, thanks for the reply.
Looking at the 67 A.M. page 374 the caption [ HYDRAULIC STEERING 396 ENG EXCEPTIONS ( RPO L35- L78 ) ], I take the word Exceptions to mean that  sheet is to be used for the assembly of L35 and L78. Am I interpreting this correctly ?
Will be at Camaro Nats. in a couple of weeks and hope to meet you and Jerry.
Again thanks for your help.
Bob C
Post by: JohnZ on June 09, 2008, 09:31:41 AM
Quote from: big iron on June 08, 2008, 11:15:46 AM
Looking at the 67 A.M. page 374 the caption [ HYDRAULIC STEERING 396 ENG EXCEPTIONS ( RPO L35- L78 ) ], I take the word Exceptions to mean that  sheet is to be used for the assembly of L35 and L78. Am I interpreting this correctly ? Bob C
Correct. That sheet (N40, sheet A10) shows the parts unique to the L35/L78 installation; the small-block V-8 installation is shown on N40, sheet A6.
Post by: 169INDY on June 15, 2008, 01:38:35 PM
Sleeve
.75" ID
1.250" OD
Oil soaked, deteriorated originals on a PS 1968 396 LOS car.
I have not found it avail via repop houses. We use a very similar material to insulate pipes on Submarines trade name 'Aramflex Insulation' I need to see if they have it in the above size. The color, density, shape, feel is very similar.
Post by: big iron on August 05, 2008, 09:48:06 PM
Jim,
Wondering if you might have an overall length on the two hoses  ???
Thanks for the reply  :)
Bob C
Post by: 169INDY on February 28, 2022, 12:17:42 AM
MCmaster-Carr
45295K54
Post by: KevinW on February 28, 2022, 09:13:09 AM
Himm, 45295K54 is silicone for $70+
I like the Neoprene tubes better.  I have used McMaster Neoprene to make Astrovent, heater box and kickpanel seals quite successfully.  I think they are a better and cheaper option.  Not sure what size would work best though (need to measure carefully).
https://www.mcmaster.com/neoprene-foam/multipurpose-blended-neoprene-foam-tubes/
Multipurpose Blended Neoprene Foam Tubes
Color: Black
Temperature Range: 0° to 165° F
Cell Type: Closed
For Use Outdoors: Yes
Density: 22 lbs./cu. ft.
Pressure to Compress 25%: 9 psi (Soft)
Tensile Strength Rating: Not Rated
Oil-Resistance Rating: Good
Neoprene is blended with EPDM and polyethylene for foam tubes that offer good resistance to water, sunlight, and oxidation. Use them as jackets, seals, and insulation. This foam has closed-cell construction, which restricts water, air, and gases from being absorbed. Tubes have an ultra-smooth texture for a sleek surface that's easy to wipe down.
3D CAD models availableFor technical drawings and 3-D models, click on a part number.
10 ft. Lg.
OD   ID   Wall
Thick.       Each
1/2"   1/4"   1/8"   2029N11   $13.90
9/16"   3/8"   3/32"   2029N17   13.29
15/16"   5/8"   5/32"   2029N18   15.80
1"   1/2"   1/4"   2029N12   23.68
1"   3/4"   1/8"   2029N13   15.37
1 5/16"   7/8"   7/32"   2029N19   22.00
1 1/2"   3/4"   3/8"   2029N14   38.10
1 1/2"   1"   1/4"   2029N15   27.82
1 11/16"   1 1/8"   9/32"   2029N2   33.50
1 7/8"   1 1/4"   5/16"   2029N21   38.09
2 1/16"   1 3/8"   11/32"   2029N22   50.22
2 1/4"   1 1/2"   3/8"   2029N23   49.29
2 7/16"   1 5/8"   13/32"   2029N24   63.11
2 1/2"   2"   1/4"   2029N16   39.81
Post by: Dave69rag on February 28, 2022, 12:41:52 PM
I used the below hose protector for a Boss 429 Mustang, seemed to work just fine:
https://www.cjponyparts.com/power-steering-hose-protector-sleeve-20-mustang-boss-302-boss-429-428cj-1969-1971/p/PSHPS/
Dave
Post by: 169INDY on February 28, 2022, 01:18:08 PM
My factory sleeve on the pressure hose is around 6" long.
The Silicone Mcmaster version is priced at .99 per inch.  better bulk pricing than half the Ford part pricing.
The neoprene hose selection looks good. Mine are very tattlered and soaked, torn, stretched and taped up
Lots of options- Nice
Post by: KevinW on February 28, 2022, 02:24:43 PM
I think the 2029N14 would be the closest at 3/4" ID, 1.5" OD (slightly thicker side wall).  $38.10 for 10' long ($1.90 for each 6" section, which you get 20 of them :D)
Or maybe 202N13 for $15.37 (slightly thinner sidewall)
I have a couple cars that need this and McMaster is close by, I think I will get one, thanks!
Post by: 169INDY on April 11, 2022, 06:30:04 PM
I did order the Expensive Silicone version and It fit Very well on the Low Pressure Hose, Impossible to install on the Crimp on HP Hose.
