Is there a vin on the firewall under the blower on a C60 equiped vehicle?
Should be...
I didn't see one after I took the blower off. Hence why I asked.
Was the firewall changed?
no, the firewall is original. The AC fan had never been off.
I will soon be removing the cowl and I will also check for a stamp
Look more to the drivers side below the hole in firewall for the A/C evaporator.
My 67 with C60 does have the VIN stamped in the usual spot by the fan location, under the AC box.
I didn't see one there either. The only stamping is an upside down H20 near one of the studs
When I get the motor out I will get in and clean the old gasket material to see if the vin is under it
I have a LOS 67 RS SS with AC and I did not find a partial vin on the firewall. There is a matching partial vin under the cowl.
