I have been researching a starter for a 69 SS 350. I have come across various sources that state different numbers. Does anyone know of a definitive list of the specific applicatons for each starter?
Thanks Chris
Chris -
See page 14 in the 1969 Chevrolet Chassis Service Manual "Specifications" section. All the starter model numbers and applications are listed there. For a 1969 Camaro SS with a 350 cid engine the Chassis Service Manual list a 1108361 starter for an automatic transmission (12.75" ring gear diameter) and a 1108338 starter for a manual transmission (14" ring gear diameter). Maybe someone with a scanner can post that page here for you if you don't have the manual. :)
Please see the thread from Camaros.net
http://www.camaros.net/forums/showthread.php?t=75939 (http://www.camaros.net/forums/showthread.php?t=75939)
This is the source of my confusion. It Leads me to believe that a 350SS could either have a 361, 338, or a 420 starter.
Chris
I tried to update this info my my new 1969 4th edition book. All of the L48 engines got the large 168 tooth flywheel, and 1108338 starter according to the data that I gathered. The low-perf 350s received the smaller flywheel w/ 153 tooth flywheel.
Jerry
