Camaro Research Group Discussion => Decoding/Numbers => Topic started by: dsags on February 19, 2008, 06:32:52 PM
Title: Quadrajet Number
Post by: dsags on February 19, 2008, 06:32:52 PM
I came across a Rochester Quadrajet with the number 29204  FF  1409. The number is NOT 7029204. Has anybody ever seen one like this ? Thanks.
Title: Re: Quadrajet Number
Post by: tim69camaro on February 19, 2008, 07:14:26 PM
I have seen several this way. One just sold on ebay with an intake. Did you buy that one? Here is a link to the website that describes the 70 being dropped on some carbs.  http://camaros.org/carb.shtml
Post by: dsags on February 19, 2008, 09:05:29 PM
Thanks for the reply. I looked at that site and missed that reference the first time.  :(
Post by: Ejam on February 25, 2008, 11:09:57 PM
so some came with the 70 and some without?
Post by: dsags on February 26, 2008, 09:35:11 AM
In the detail for a 29200 carb for sale on eBay the seller said "all 1969s manufactured in this time period had the entire number on one line and to do this they eliminated the 70. Later on the date code was dropped below the oem number of the carburetor". His carb was dated 0149. Mine is 1409 or May 20th. It would seem that in this date range the 70 would be missing IF his statement is correct.
Post by: Ejam on February 26, 2008, 03:12:14 PM
l have one with the 7029200 dated 0289 all on one line
http://i258.photobucket.com/albums/hh272/ejam69/20062007291.jpg
http://i258.photobucket.com/albums/hh272/ejam69/DSCN1931.jpg
Post by: bertfam on February 26, 2008, 04:58:38 PM
Read THIS (http://www.thecarburetorshop.com/Rochesterquadrajetmarkings.htm) gents. When I was writing the report, I emailed Jon Hardgrove about several things including this. He said there never seemed to be a rhyme or reason for the 5 digit stampings, but it appears mostly in 68 and 69 carburetors (although he's also seen it in later carbs).
Post by: Ejam on February 27, 2008, 11:19:22 AM
l like the application for 69 396 a/t being 7029200
Post by: dsags on February 27, 2008, 09:36:45 PM
Thanks for setting us straight Ed. Another myth bites the dust.
Post by: opelitis1 on February 28, 2008, 07:10:01 AM
I have a couple of 29202 DH 0869 units, I will check the Julian date as I have them being the same (0869) for both.. How rare is that to have 2 of the same date???
Also have an '69 Olds 29251 RJ 1149 and a '72 Olds 2251 (only 4 digits) then RE 2651.
Hope I haven't sullied the Camaro parts with Olds parts numbers, but I kinda found it interesting that there was a 4 digit code i.e. 2251..
Some of the older carbs I have are seized: 7026202 - data disc unit   - one of the  two 29202 units   - and a 7029268 ('69 Poncho) is seized.  Not a real load of rust on these carbs, but, what is a safe way to "free 'em up" without killing the throttle plates and associated linkages???  T.
