Camaro Research Group Discussion => Decoding/Numbers => Topic started by: dmc on January 23, 2006, 09:12:27 PM
Title: 67 convertable 10 bolt rear decode issue
Post by: dmc on January 23, 2006, 09:12:27 PM
I have a 67 convertable 327 210hp with a powerglide trans. The rear is a 10 bolt but I can't read the stamp due to rust and pitting. The pop location F numbers are BP0420G. any ideas?
Title: Re: 67 convertable 10 bolt rear decode issue
Post by: 67ss350camaro on January 24, 2006, 07:29:18 AM
That is a fairly common axle for a base line Camaro.  It is a 3.08 non-posi 10 bolt.
I don't believe we have your car in our data base.  If you would like to have it added, e-mail me.
Post by: dmc on January 25, 2006, 02:33:29 PM
The motor has been converted to 275 hp 327 and I wanted to change the gears in the rear to 3.55 or 3.73, is there any problem with that?
