Camaro Research Group Discussion => Decoding/Numbers => Topic started by: swxxl on January 31, 2008, 06:45:42 PM
Title: CAN SOMEONE HELP ME WITH MY 69 IT IS A WEARD ONE!
Post by: swxxl on January 31, 2008, 06:45:42 PM
I bought a 69z in 2000. the color original color is daytona yellow with a black vinle top so the tag says.
the tag also says it was built in oct of 1968 there for it has no x code on the cowl tag. But here is the thing this car has the original m22 tranny AKA"ROCK CRUSHER" with the vin of the car on the side of the case. I t also has the orignal 12bolt rear axel in it with 4 multi leaf springs. but no 302 motor so i searched from person to person who owned the car to try find the motor or hopefully the original owner. The guy that owned it back in 1976 said he had drove in high school and said he pulled the 302 cause he spun the rod berring. But because the car has no x coed and also no tach or console i dont know for sure if it is a z28 or not. This guy also had pictures of the car in the late 70s with the z28 emblems on it. A few other things about this car is it has disc brakes and the hangers are still there for the chambered exhaust and it has the Rs package with the orignal yellow paint on the back of the hidden headlight covers. With all of that junk attached to the side of the wiper motor that workes the headlight covers.
Is there anything else i can do to find out what this car is . If it is a z why dont it have a tach or no power steering.   Is this car a special order car that someone might have ordered with m22? I have no clue  this thing is driving me crazy. CAN SOMEONE PLEASE HELP ME!!   I DONT KNOW WHAT ELSE TO DO.
Title: Re: CAN SOMEONE HELP ME WITH MY 69 IT IS A WEARD ONE!
Post by: Jerry@CHP on January 31, 2008, 07:13:17 PM
Factory M22s were only installed in HP models such as L78, L89, L72 and Z28.
Jerry
Post by: x77-69z28 on January 31, 2008, 08:01:58 PM
everything else for the z besides the power disc brakes was optional. you could get it with no tach, no guages, and power steering was actually rare for a z-28. if you dont have jerry's definitive 69 z-28 t. look for the brace on the left rear chassis rail for dual exhaust, as all z's had dual exhaust.
good luck
Post by: swxxl on January 31, 2008, 09:15:33 PM
SO WOULD TE M22 BE PROOF ENOUGH TO SAFELY SAY IT IS A TRUE Z?
Post by: bertfam on January 31, 2008, 09:32:59 PM
Not with all the restamps out there. You really should have Jerry certify it for you. Short of that, post a picture of the VIN stamping on the transmission and we can tell you more.
Post by: Jonesy on February 01, 2008, 09:46:51 AM
How do you know its an M22???
Post by: mrdetails on February 01, 2008, 12:18:57 PM
Also check for a single 3/8" dia. fuel line which would indicate a Holley carb (high perf.) 2 fuel lines 3/8" with 5/16" no Z28.
Good Luck
Sam
Post by: swxxl on February 01, 2008, 04:36:16 PM
I WAS REPLACEING THE CLUTCH AND I FOUND THAT THE INPUT SHAFT HAD A CRACK IN IT SO ORDERD A NEW SHAFT FOR A M21
THAT IS WHAT I THOUGHT IT WAS. WHEN I GOT THE M21 INPUT SHAFT I TRIED TO INSTALL AND IT WOULD NOT FIT.  I CALLED   THE TECH WHERE I BOUGHT THE SHAFT AND WAS EXPLANING THAT THE GEARS ON THE SHAFT WERE SLANTED MORE THAN MY OLD SHAFT. THEN EMEADETLY HE SAID "YOU HAVE A M22 I WILL SEND THE RIGHT PART" AND I INSTALLED THE NEW SHAFT WHEN IT CAME IN AND IT HAS WORKED GREAT SINCE.  AND IT WINES ALOT I HAVE ALWAYS HEARD THAT IS NORMALY HOW THE M22S SOUND.
Post by: Gramps69Z on February 01, 2008, 10:55:21 PM
swxxl, please take the caps lock off, it's hard on my old eyes.
Post by: swxxl on February 02, 2008, 08:10:58 AM
Sorry im from kentucky not verry good with computers.
Post by: L78 steve on February 06, 2008, 10:50:01 AM
Something that I learned on this site to check,If you have the short steering arms and the long pitman arm.
Post by: plumL78 on February 07, 2008, 11:32:49 AM
Does it have X3  on the bulk head behind the back seat ?
Post by: swxxl on February 17, 2008, 09:11:12 PM
how do i post the pictures on here?
Post by: swxxl on February 17, 2008, 10:41:20 PM
http://s266.photobucket.com/albums/ii272/swxxl/
click this link to photobucket to see the pics of my car.
Post by: KurtS on February 17, 2008, 11:47:13 PM
Is the P9P09 or P9R09 on the trans?
Trans stamp looks original.
What's the axle code? http://www.camaros.org/drivetrain.shtml#RearAxleNumbers
Post by: swxxl on February 18, 2008, 12:00:17 AM
P9P09 is the stamp. and the axlecodes are so badly rusted i need to wire brush them to find out
Post by: swxxl on February 18, 2008, 12:02:45 AM
P9P09 is what is stamped. the axle codes are so badly rusted i cant read them until i wire brush them
Post by: 1968RSZ28 on February 18, 2008, 02:56:52 AM
Quote from: swxxl on February 18, 2008, 12:02:45 AM
swxxl -
I'm assuming this stamp (P9P09) is stamped on your transmission...
P = Muncie 4-speed transmission
9 = 1969 model year
P = September
09 = day of the month
So what you have is a 1969 Muncie 4-speed transmission assembled on September 9, 1968.     :)
Post by: swxxl on February 18, 2008, 07:52:02 AM
on the cowl tag it has a 10b is that black vinyl top or black stripes ? and why does this tranny not have a C stamped beside the P9P09?
Post by: swxxl on February 18, 2008, 08:41:09 AM
i added some more pics of car steering arm and possibly dual exhast brackets?
Post by: Gramps69Z on February 18, 2008, 08:53:02 AM
10 B is 2nd week in October,  the car color code 76 B is Daytona Yellow with a black vinyl top.   C next to the transmission date code is M22.    If you click on the CRG header in the top right of the forum page, you will find great information on the car.    ;)
Post by: jdv69z on February 18, 2008, 09:34:50 AM
Quote from: swxxl on February 18, 2008, 07:52:02 AM
My 10B Z/28 does not have letter suffix on trans either; Mine is P9P11 within 2 days of this one; Suffix was not added until about 3rd week of Oct 68, I believe. Looks correct to me.
Jimmy V.
Jimmy V.
Post by: m22mike on February 20, 2008, 11:16:35 AM
Quote from: Jerry@CHP on January 31, 2008, 07:13:17 PM
Jerry
Kurt, Jerry, anyone....opinions on this ?
My 69 X66 05A car has  the born/w factory M22 vin# stammped trans.
There are no doc's on the car. So would it be safe to say there should be no dispute to my car being a factory built L78 ?
            Thanks Mike
(http://i18.photobucket.com/albums/b107/m22mike/tn_banner.jpg)
Post by: Iluv69s on February 20, 2008, 07:52:53 PM
When Jerry came to my house to verify my L78 69 INDY, one of the major proofs that he used was the original born-with M-22......your M-22 trans(assuming original) proofs 100% the car was a solid lifter car...ie... Z28,L78, COPO...I'm no expert, but I thought Id chime in because of the similar situation...correct me if I am wrong...
Post by: Steve Shauger on February 20, 2008, 10:39:16 PM
Quote from: m22mike on February 20, 2008, 11:16:35 AM
Jerry
            Thanks Mike
Yes, based on it in fact being original to the car.
Post by: m22mike on February 21, 2008, 08:15:30 AM
Thanks for the replies guy's, I will try and post a shot of that stamp if there is any interest ?
I guess after 9 yrs. :o  I should get some info to Kurt for the DB.
Post by: swxxl on April 05, 2008, 03:42:28 PM
So would this car have a cowl hood and black stripes?
Post by: L78 steve on April 05, 2008, 07:00:18 PM
To early for cowl hood .
