Camaro Research Group Discussion => General Discussion => Topic started by: Sean McRae on January 24, 2008, 01:11:31 AM
Title: Verification of Car's History?
Post by: Sean McRae on January 24, 2008, 01:11:31 AM
Does anyone know of a source or database that can retrieve the history of a Camaro, such as the way the car was equipped?  My build sheet is mostly unreadable.  I would like to find supporting documentation for my restoration efforts.  The car was Los Angeles built February 6, 1969.
Title: Re: Verification of Car's History?
Post by: Brandan on January 24, 2008, 11:20:02 AM
unless it was sold in Canada you are probably out of luck.   I have been trying to find out more info on my cars with no luck.  at least you have a build sheet.
Post by: lakeholme on January 24, 2008, 02:55:41 PM
Beyond printed factory documentation --that build sheet, POP, and the like-- your best sources of information are the previous owners.  Don't assume that's impossible, if it is not readily apparent.  I traced a 68 all the way back to the original dealer and owner last yeat, starting with just a receipt from Florida.  I picked up copies of titles, full set of pictures of a previous restoration, bill of sale --everything except that POP-- along the way.
Post by: KurtS on January 25, 2008, 02:16:25 AM
If you can get me a high resolution scan of the broadcast sheet, I should be able to decode the options it shows for you.
