Camaro Research Group Discussion => Decoding/Numbers => Topic started by: gumpyg40 on January 02, 2008, 05:19:20 PM
Title: 67 camaro SS=rear axle decode
Post by: gumpyg40 on January 02, 2008, 05:19:20 PM
hi---got the numbers off rear axle leg===BP 0117G2.....as you are facing rear end  B7890 top right and below it... 1  345   and the top left  A 8 9......thankyou
Title: Re: 67 camaro SS=rear axle decode
Post by: rich69rs on January 02, 2008, 06:35:45 PM
Check here:  http://www.camaros.org/drivetrain.shtml#RearAxleNumbers
BP in '67:  3.08:1, 10 bolt, non posi rear axle assembly
0117:  Axle assembly date, i.e. January 17 (1969?  see below with regard to the housing casting date)
G:  Detroit Gear and Axle Plant
2:  Second shift
B7890 (should be 67890) and 345 are test marks
A 8 9 is the casting date.
A = January
8 = day
9 = year, i.e. 1969
The casting date would indicate that the axle assembly is not a '67 axle but rather a 1969 assembly with housing casting date of Jan 8, 1969.   BP in 1969 was a 2.73:1, 10 bolt, non posi rear end.
Post by: gumpyg40 on January 02, 2008, 06:58:18 PM
ok    thankyou richard===this car was at one time a drag car out of the mojave--so calif area....i may be in for a surprice when i pull the cover off---i
