When I purchased my Z10 the engine had the Z/28 style aluminum covers. I would like to find a set of stamped steel covers and ran accross these on ebay. These are suppose to be from a 68 Chevy. Would they be correct for my L48?
Kris
They are not the correct covers. No extra brackets as those have. The RS has a breather hole and the LS should have an oil fill hole and PCV hole.
Jerry
Thanks Jerry I'll keep looking.
Kris
i have a set that i use to when i paint an engine. if i am not mistaken, they are the original valve covers off my z-11 car that i owned in 1974 and 75. i will check them out and let you know. i have a friend that needs a set for a 68 if you could send me the link for the auction on ebay.
thanks
buddy
Buddy,
Here you go. Hope it works. http://cgi.ebay.com/ebaymotors/Smallblock-Chevy-valve-covers_W0QQitemZ160193675445QQihZ006QQcategoryZ140696QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Kris
Just a FYI.....Those are NOT 68 valve covers. They should not have to oil cap in 68...The 68 covers are a one year only cover and can be very difficult to find in nice condition. Also 68 covers are stamped with an O between the top two bolt holes on the top/intake side of the cover...Good luck!
