Camaro Research Group Discussion => Decoding/Numbers => Topic started by: Camaro Billy on November 29, 2007, 11:56:52 AM
Title: Distributor Date
Post by: Camaro Billy on November 29, 2007, 11:56:52 AM
Is a #1111489  -  8 H 21 (Aug 21st 1968 ) dated distributor too early for my 11D (4th week Nov. 1968 ) build car ?
I'm having allot of trouble finding a date correct one, and this is the closest I've found yet.
Thanks for any help.
Billy
Title: Re: Distributor Date
Post by: tim69camaro on November 29, 2007, 08:08:09 PM
The date should be on or before the engine build date stamped on the pad. The closer the better. That far in advance seems to be outside the range prefered based on what I have seen. There are always exceptions, but if you don't have the known original those exceptions would not apply.
Post by: Jonesy on November 29, 2007, 09:05:07 PM
My 11B has it's orig 1111488 distributor and it's dated 8 H 29, so it could be possible.
Post by: Jerry@CHP on November 29, 2007, 10:28:21 PM
Billy,
That date is fine for an early car.  These parts were made in big runs and from time to time there is a wide gap.  The famed Brandenburg survivor car in the beginning of my book is a mid Feb built car and it has a factory installed 8K30 1111480 distributor in it.
Jerry
Post by: KurtS on November 30, 2007, 02:32:32 AM
I pulled one out of a L48 that was a December motor with an earlier than your distributor. Use it. :)
Post by: Camaro Billy on November 30, 2007, 07:09:38 AM
Thanks Guys, I going to see if I can snap it up.
Billy
Post by: 1968RSZ28 on November 30, 2007, 02:07:22 PM
Quote from: Camaro Billy on November 30, 2007, 07:09:38 AM
Well Billy, did you buy it?  Are you "sugaree908"?     ;D
Post by: Camaro Billy on November 30, 2007, 03:58:25 PM
Paul,
That's Me ! Kinda tough without a picture, but I've been looking for one for a long time. Now I just have to have Jerry rebuild it for me.
Billy
Post by: DAL777 on November 30, 2007, 05:31:43 PM
Billy,
I have an 11D car and it has a    8 J 18  which I believe is original.  The engine is  T 1106HB.
Post by: Jonesy on December 01, 2007, 05:04:27 PM
Quote from: DAL777 on November 30, 2007, 05:31:43 PM
Billy,
Thats about 19 days after my 11B car. they didnt use "I" for the month stamping on distributors
Post by: DAL777 on December 03, 2007, 08:59:48 PM
So that makes mine about right?
Post by: 1968RSZ28 on December 03, 2007, 09:54:25 PM
Quote from: DAL777 on December 03, 2007, 08:59:48 PM
And for a reasonable price too!     ;)
Post by: tinman75 on December 15, 2007, 07:07:00 AM
I have a 68 L48 survivor 10D with 4 spd. trans. my distributor part # is 1111264 which is a correct 68 part # and the date is  7J5. I was wonderinging the same,  if it was to far apart but the part # matches the car perfect and the rest of the parts in the motor all are within 2 months.
Post by: JohnZ on December 15, 2007, 11:06:24 AM
Quote from: tinman75 on December 15, 2007, 07:07:00 AM
That's September 5th - if it's prior to the stamped engine assembly date on the front pad, it should be OK.
Post by: tinman75 on December 15, 2007, 06:25:40 PM
but it is a 10D 68 car and it is marked 7J5 and from what I am understanding the 7 stands for 67 or am I wrong?
Post by: 68Zproject on December 15, 2007, 07:04:42 PM
Your 68 model car was made in 67.  The dist. stamp is the date it was made up, not the model it's for.
Post by: JohnZ on December 16, 2007, 10:08:13 AM
September '67 distributor is fine in an October '67-built '68 if the distributor date is prior to the engine assembly date.
Post by: Steve68 on December 16, 2007, 11:16:42 AM
It appears to me his car was made in the 68 "model" year in the 4th week of September (10D) in 1967 and his distributor was made September 5th 1967.  The distributor would seem to be a match to me.  What have I overlooked?
Post by: 68Zproject on December 16, 2007, 07:23:11 PM
It's like John Z said, if it's before the date on the engine assembly stamp, you're cool.
Post by: Steve68 on December 17, 2007, 10:13:04 PM
John, how were you able to edit your response (post #16) almost 26 hrs after your original one?  My post was based on yours but now that you have changed it mine appears out of place or not to refer back to anything.  If you have editing power to remove mine then please do.  Thanks.
Post by: tinman75 on December 20, 2007, 05:27:45 AM
68Z,  distributer part numbers are marked on the unit next to the date for the correct motor it goes with.
Post by: 68Zproject on December 21, 2007, 12:47:20 PM
I meant time-wise, not location.
