Camaro Research Group Discussion => Originality => Topic started by: earl on January 08, 2006, 10:23:13 PM
Title: 1968 ss rs 396 325 hp fan
Post by: earl on January 08, 2006, 10:23:13 PM
can anyone tell me what the correct rad. fan looks likeĀ  or have pic's for 1968 ss rs 396 325 hp. no ac and what length fan spacer
thanks
Title: Re: 1968 ss rs 396 325 hp fan
Post by: 68rsssrag on January 09, 2006, 12:53:03 AM
Earl
Look at the CRG Reports section on the maun webpage. There is a ful report with all the info you are asking.
Cheers
Arno
Post by: KurtS on January 09, 2006, 02:02:12 AM
Earl,
Please don't post the same question in multiple forums, once is fine. :)  I deleted the other two posts.
Thanks!
Post by: earl on January 09, 2006, 02:02:33 PM
Quote from: KurtS on January 09, 2006, 02:02:12 AM
Earl,
Thanks!
sorry about that i did not know were to post
Post by: earl on January 09, 2006, 02:11:43 PM
Quote from: 68rsssrag on January 09, 2006, 12:53:03 AM
Earl
Cheers
Arno
thanks thats what i needed
Post by: Pex68 on January 09, 2006, 06:22:14 PM
Got a question on this one, how many people actually have the 4 blade fixed fan on their 396/325 and how many have a clutch fan?  Would be interested in the year and what options also.  Mine came with the fixed 4 blade fan and I replaced it with the clutch fan because the fixed fan had a stamp on it that read FoMoCo and I took that as Ford Motor Company and obvoiusly not right.  anyone else seen this???  Found the CRG report a while ago and have been questioning it ever since.
My car is a 68/396-325/M20/no AC.
Post by: earl on January 09, 2006, 10:09:57 PM
mine is a 4 blade but i can not find any#s
Post by: KurtS on January 10, 2006, 04:42:24 AM
Most L35 cars got the 4 blader.
I've looked at enough docs to say that. :)
Post by: earl on January 25, 2006, 12:04:21 AM
do you have some pics of the 4 blade fan
Post by: Steve68 on January 25, 2006, 08:35:57 PM
Earl
Go to the CRG Reports button in the upper left corner and click on it.  Then click on the "cooling systems" report and go to the bottom of the page and you will find a picture of the 4 blade fan.
Post by: tim68rsss on February 03, 2006, 11:22:01 AM
Interesting Fact: My 68 RSSS 396/325 Auto (build date 11/67) with AC came with a four blade fan unless the original owner switched it out. I know the report says that it should be a five blade fan with clutch. I'm 99.9% sure my setup is original though. Car only has 52000 miles and I have all of the orignal engine components (water pump, alternator, and starter) which I had rebuilt. The fan spacer was still attached to the water pump when I bought the car. Car also has the 4-core Harrison radiator.
