Camaro Research Group Discussion => Mild Modifications => Topic started by: pcmech on September 29, 2007, 02:22:18 PM
Title: suspension swap 1969
Post by: pcmech on September 29, 2007, 02:22:18 PM
we have a totalled 1997 z28 & were curious if anyone had info about swapping into a 1969 camaro... full suspension/brakes or just part
thank you for your time
Title: Re: suspension swap 1969
Post by: JohnZ on September 30, 2007, 12:34:48 PM
Totally different design, smaller/weaker ring & pinion/diff; why would you want to swap that in?
Post by: Bjv69ss on November 11, 2007, 08:51:09 AM
If you are looking to have a better handleing and stopping car... I'd part out the wreck if you need the cash first and buy a brake up-grade and add 4 wheel discs. As for suspension there are tons of kits and parts out there.  Just changing to a 1" sway bar up front and adding a rear sway bar will make a big difference.  Poly bushings front and rear will also help.  I did the latter on my convert.  Made a huge difference!
