Camaro Research Group Discussion => Maintenance => Topic started by: Mark's 68 L78 RS SS on August 19, 2007, 11:49:54 AM
Title: Sloppy steering
Post by: Mark's 68 L78 RS SS on August 19, 2007, 11:49:54 AM
The steering in my 68 is very sloppy. Is this just a marginal design from the factory or are there some things in the steering and front suspension that I should be looking at? Is there a way to tighten up the steering while maintaining everything stock or at least easily able to go back to factory correct?
Thank you,
Mark
Title: Re: Sloppy steering
Post by: rich69rs on August 19, 2007, 01:27:23 PM
A 1st Gen stock Camaro isn't going to handle as well as a performance car of today.  My daily driver (which I bought new) is a '95 Z28 that handles significantly better than my '69RS which is totally stock but does have N40 power steering and N44 special steering, quick ratio option.  However, to get the best out of the stock setup, start by ensuring that everything with the suspension is pristene, i.e. back to basics: good ball joints, tie rod ends, relay rod, end links, etc.  Also, RPO N44 helps (2.2 turns lock to lock).  See following link for the best overall 1st Gen suspension / steering write up I've come across:  http://www.pozziracing.com/first_gen_suspension.htm.
Especially pay attention to the section on steering:  http://www.pozziracing.com/camaro_steering.htm#Steering_linkage
Post by: JoeC on August 20, 2007, 07:45:57 AM
there is a steering box adjustment you can try
best to check a repair manual to get the info
