Camaro Research Group Discussion => Originality => Topic started by: MARK B on June 29, 2007, 07:56:38 PM
Title: hey guys need your input
Post by: MARK B on June 29, 2007, 07:56:38 PM
hello guys,
first question is
what would be the correct mono leaf springed open rear end for
a base coupe with the engines listed below?
327 210 hp with a saginaw 3 speed manual trans
327 210 hp with a saginaw 4 speed manual trans
would it be one of these  >>>>  2.73 or 3.08
i was just trying to find an 10 bolt open rear that would have been originally
used in my 68 born in the forth week of april 68
also what would be the stamped axle code and casting date?
second question is:
what are the part numbers for speedo cables for the above engines also.
also kurt i found out by removing my rug that my 68 was a non console
floor shifting car(does this sound right)
someone tact welded a piece of sheetmetal over the original shifter hole
then cut up the trans tunnel for a hurst super shifter.
thanks for your help and input guys
also sorry for the long post
mark b
Title: Re: hey guys need your input
Post by: PURESS on June 29, 2007, 08:49:35 PM
Hey Mark....My first 69  had a 327/210 and was a three speed(on the floor)(no console)..one wheel wonder...2.73...scott
Post by: hotrod68 on June 29, 2007, 09:49:56 PM
Mark...my '68 is a very early Norwood car and it had a 3:08 open 10-bolt originally. I still have it. It was a 327 car with a console and I figure it had to have had a 3-speed or Saginaw 4-speed because it has monoleafs. God only knows what transmission came in it from the factory because the data plate on the firewall is long gone. But consoles were the exception rather than the rule. And I can relate to some idiot butchering the transmission tunnel--when I got my car in '83 there was a HUGE hole where someone had installed the Mr. Gasket Vertical-Gate shifter on the M-20 that was in it. I've since made a patch and welded that gaping hole closed! Good luck on your car!
Post by: bertfam on June 30, 2007, 12:21:24 AM
Mark,
The base V8 engine (327/210) would have come standard with the 10 bolt 3.08 ratio with either the 3 speed manual or the 4 speed manual. The 2.73 was the optional "economy" ratio while the 3.55 was the optional "Performance" ratio. The stamping for the 3.08 would be "PA" and the date would be a day or so, to a few weeks prior to the cars build date.
The speedometer cable part number would have been P/N 6477132 (or P/N 3878814) for the base 3 speed, and P/N 6454863 (lower) and P/N 6477129 (upper) for the 4 speed. (The Saginaw 4 speed used a 2 piece cable.)
Post by: MARK B on June 30, 2007, 12:27:53 AM
hello everyone,
thanks for your replys and input with my questions.
hey bertfam, a big thank you to you for your info and part numbers.
i dont have a speedo cable on my car now but i wanted get the correct one
to put back on the 68.
thanks for your time guys,
mark b
Post by: bertfam on June 30, 2007, 12:52:51 AM
Mark,
I made a mistake on the part numbers. I've edited the above to reflect the correct numbers.
