Camaro Research Group Discussion => Maintenance => Topic started by: that_rabbit on November 28, 2026, 04:57:53 PM
Title: 1968 Camaro SS 350 (4-Speed / Quadrajet 7028213) – Warm Engine Off-Idle Stumble
Post by: that_rabbit on November 28, 2026, 04:57:53 PM
Hi everyone,
I recently picked up a numbers-matching 1968 Camaro SS 350 Convertible and am working through a few initial shake-down items. I'm running into an acceleration bog and off-idle stumble once the engine is up to operating temperature, and I'd appreciate any guidance or experience you all can share.
Car & Drivetrain Specs:
• Model: 1968 Chevrolet Camaro SS 350 Convertible (Norwood build, 12C)
• VIN: 124678N360461
• Engine: Original 350 CID / 295 HP V8 (Pad stamp: V1129MS / partial VIN 18N360461)
• Transmission: Muncie 4-speed manual
• Carburetor: Rochester Quadrajet 4MV, stamped 7028213 (divorced mechanical choke, non-A.I.R. setup)
Symptoms & What I've Checked So Far:
• Once the engine is fully warmed up, giving it a small amount of throttle from idle causes it to stumble/stall, and it bogs under throttle tip-in.
• With the engine off and air cleaner removed, I watched the primary bores while cycling the throttle linkage by hand. I see an initial squirt of fuel from both primary discharge nozzles right as the throttle opens, but the stream does not continue throughout the rest of the throttle stroke—it cuts off partway through. I recorded a video and it's viewable at this link: https://drive.google.com/file/d/117dy5ZpMeCvCA7dPb_t8SpwCRxDzWMHn/view?usp=share_link
Questions for the Group:
1. On a 7028213 Q-jet, is this pump shot normal? I had read that the fuel should be continuously squirting and that is not the case.
3. Anything else on this setup that commonly causes a warm tip-in bog?
Thanks in advance for any insight!
Title: Re: 1968 Camaro SS 350 (4-Speed / Quadrajet 7028213) – Warm Engine Off-Idle Stumble
Post by: 1968RallySport on November 28, 2026, 06:11:16 PM
Sounds like your accelerator pump cup has dried up, common problem. Either replace the cup or rebuild the carburetor. Your choice.
https://quadrajetpower.com/products/accelerator-pump-assembly-with-air-horn-gasket?_pos=1&_sid=28954f873&_ss=r&_su_rec=CzypXmf3CNuclAcNqkgM7B6kfxg2VnK8iYcYV2W8WDo_z4KrJGlfSzWFo1nWSEo0dsw8i7SMhRDh8VbLey7II2hc7nLCjQn91TFipBHipZUss46otAi48i7AXjgtR8oItXWFvmr3fkDwSavBLykb1N8gJoserpuRQMA14j-SgW-_JNCvbCzbXA7bxCLzBq3KxDx2xvzr5MejwMEcS36RKNAUGiqxOiEhtCr74yV0SuqIStCnvpRhXtaI01FK1bu_wJZdB2EihK6r3IY6kUvobViGoOD_liv9X_LhmF50X6HGFG7EYqaYQwmbN7L3p6fUeRg0G-0Gd8RpqM1xwKPvKKg2cNqY4nFYGY41ZW4quxeyyesBnlzYVldKVvhgW2E2-6taZ3zzUfTB3o448ytJr6WBXcJB8xBjQ7PHjb1UDw&_su_rec_id=4d2d4af8-6910-45ce-bfca-8f0b05224551-1795907498
Post by: David K on November 28, 2026, 06:21:38 PM
Yup, accelerator pump.
Post by: camaronut on November 29, 2026, 08:29:20 AM
Today's gas does not react well with carburetors and rubber hoses on our cars.  I suggest using Sta-Bil Marine in a full tank of gas to help.  It helps keep anything in the gas stream safe from the affects of Ethanol.
Post by: that_rabbit on November 29, 2026, 05:48:28 PM
Thanks, everyone. I really appreciate the support and your expertise. Dad and I are going ahead with the accelerator pump replacement (thanks for including that link, too, super helpful). Wish us luck!
Post by: GMAD_Van Nuys on November 30, 2026, 01:24:16 PM
I would recommend that you check your ignition timing (stock - 0 degrees @ 700 rpm hot with vacuum advance plugged).  My 1979 Pontiac ran similar to your 1968 Camaro and I found out the ignition timing needed to be adjusted.
