I split your post out into its own thread.
Full VIN is 124378N411381
That makes it show up with searches from search engines.
Subject: 1968 Z/28 MO-Code Block Available (Orphan)
Component: Engine Block
Engine Suffix Code: V0402MO (Flint assembled, April 2nd, 1968 Z/28 302ci)
Block Casting Number: 3914678
Block Casting Date: C278 (March 27, 1968)
Partial VIN Stamped: 18N411381
Assembly Plant: Norwood, OH (N)
Estimated Vehicle Build Date: early April 1968
I have a 1968 MO-code engine block with the partial VIN 18N411381. Casting number is 3914678, casting date C278, and engine pad stamp is V0402MO. I am looking to reconnect this original, matching-numbers drivetrain component with the vehicle it belongs to.
If you are the current owner of this specific Z/28, please send me a private message (PM) through the forum with proof of ownership (such as a photo of the hidden VIN or trim tag) so we can discuss reuniting the block with the car.
By the way, the car is listed here at this link.
https://kurzmannsautos.com/1968-chevrolet-camaro-z-28-numbers-matching-survivor-grotto-blue/
And discussed here.
https://www.yenko.net/forum/showthread.php?t=182643
Do you have any pics of the stampings you can post?
I do, I purchased it from a guy in Sioux falls, SD. THE pistons are 30 over, the crank(1178) is R10 & M10,.I'm not sure how to post pics here, so if you can help me out that would be great.thanks for the information. Very interesting.
I have other pics, thanks
