Camaro Research Group Discussion => Originality => Topic started by: philip on January 28, 2026, 12:36:40 PM
Title: 67 l30 m20 convertible rear springs
Post by: philip on January 28, 2026, 12:36:40 PM
Hi guys , from france,  i own my L30M20 67 since 1988 and i restored it litle by litle.
Last year the engine , this year the rear end.
I remove the spring today  , and instead of a single leaf , i have a second one bellow and no pad under the leaf.
I know that export models where equiped with F41 option.
Does this second leaf is a part of this option ?
Title: Re: 67 l30 m20 convertible rear springs
Post by: KurtS on January 29, 2026, 01:39:02 AM
No, 67's only had monoleafs - someone added the little one.
Post by: philip on January 29, 2026, 02:29:59 AM
Thanks KurtS...
That's strange cause there were  not a lot of parts avalaible in france before internet and i own this car since 1988
Maybe a GM mod for french export ?
Post by: philip on January 29, 2026, 12:41:32 PM
I have the confirmation.
It's original for french import , i found the correct paint color on the small leaf , and a friend 67 convertible have the same small leaf.
Generaly , export models have differets settings for suspension koni choc absorbers....
European people don't like too soft ...
KurtS the french camaro is back, i know you where at the old one.
https://www.chevrolet-camaro.fr
Post by: bcmiller on January 29, 2026, 01:22:43 PM
Can you post pics of the second leaf and the documentation supporting its use?
Post by: philip on January 29, 2026, 01:38:16 PM
Yes i will try to do that.....photo i just need to'remember how ,  but i don't have any documentation .
Post by: philip on January 29, 2026, 02:46:34 PM
(https://i.postimg.cc/VLLvyTf5/1000026275.jpg)
Post by: philip on January 29, 2026, 02:47:33 PM
(https://i.postimg.cc/8cy1PppR/1000026273.jpg)
Post by: philip on January 30, 2026, 02:52:42 AM
(https://i.postimg.cc/d0p8rb2Z/20260130-084842.jpg)
Here a picture of the both.
The leaf added by GM for the export models is 95cm [35"] long.
Post by: KurtS on February 03, 2026, 03:20:57 PM
Hmm, I'm still a doubter that it was an original assembly line part. There are no parts in the part manuals and there were several different rear springs for the various applications. https://www.camaros.org/images/pages/chassis/springs_67.jpg
Adding an extra leaf would make the spring taller than the spring perch - that's not a minor change.
Correct based on what? What color?
Post by: CantRepeat on February 05, 2026, 06:39:57 AM
Kurt,
What is the model 37 in reference to?
Post by: bcmiller on February 05, 2026, 09:56:53 AM
Quote from: CantRepeat on February 05, 2026, 06:39:57 AMKurt,
I am not Kurt, but can answer.
37 - coupe
67 - convertible
It is from the VIN.
Post by: bcmiller on February 05, 2026, 10:08:50 AM
That may have been a local modification made by a shop. Might have done both cars.
Please show the spring perch area with the spring in place if you have a photo.
Post by: philip on February 06, 2026, 02:54:35 AM
Quote from: KurtS on February 03, 2026, 03:20:57 PMHmm, I'm still a doubter that it was an original assembly line part. There are no parts in the part manuals and there were several different rear springs for the various applications. https://www.camaros.org/images/pages/chassis/springs_67.jpg
A blu gray color.....
Post by: philip on February 06, 2026, 02:56:22 AM
Quote from: bcmiller on February 05, 2026, 10:08:50 AMThat may have been a local modification made by a shop. Might have done both cars.
I will make one , i change side by side , so the other is ''stock'' for the moment....
Post by: CantRepeat on February 06, 2026, 05:21:58 AM
Quote from: bcmiller on February 05, 2026, 09:56:53 AM
37 - coupe
67 - convertible
It is from the VIN.
Thanks Byron! It's obvious I'm working with less gray matter every day!
Post by: philip on February 06, 2026, 01:13:30 PM
(https://i.postimg.cc/QCrktTCG/20260206-140447.jpg)
Post by: philip on February 06, 2026, 01:14:41 PM
(https://i.postimg.cc/kgkVqdBJ/20260206-140100.jpg)
Post by: philip on February 06, 2026, 01:16:07 PM
(https://i.postimg.cc/HnhYzQMp/20260206-140547.jpg)
Post by: philip on February 06, 2026, 01:18:20 PM
(https://i.postimg.cc/sgzY4sD1/IMG-20260206-WA0004.jpg)
Post by: bcmiller on February 06, 2026, 01:28:28 PM
Was there a rubber spring isolator pad in place between the leaf spring and the spring perch when you took it apart?
Post by: philip on February 06, 2026, 02:29:12 PM
Quote from: bcmiller on February 06, 2026, 01:28:28 PMWas there a rubber spring isolator pad in place between the leaf spring and the spring perch when you took it apart?
Only on top , no below....
Post by: philip on February 06, 2026, 02:33:16 PM
(https://i.postimg.cc/xCKXpbds/IMG_20260206_WA0005.jpg)
Post by: philip on February 07, 2026, 03:20:37 PM
Do you know if the ref of the spring is stamped on the leaf (3909941 or 3920220 for my car ) ?
 If yes , where ?
I know there's a paper tag with 2 letters  but in about 60 years , gone..
Post by: KurtS on February 07, 2026, 09:27:35 PM
There are not stamped #'s on the springs.
Post by: philip on February 08, 2026, 03:36:39 AM
Thanks kurtS.....i will send you by email a PowerPoint a friend make several years ago to explain the differences between US and french model.
So what to do ? Réinstall the added leaf or remove it ?
Post by: MO on February 09, 2026, 01:39:27 AM
Technically, if they can't be validated, they should be removed. However, it's your car, and if you want to keep them on then do so. It really depends on what your goal is.
Post by: bcmiller on February 10, 2026, 01:26:18 PM
I don't think they are original but I can't say for sure.
If proof can be found that they are original, I would be interested in knowing the details as to when, why and how the change was made.
Best wishes.
Post by: KurtS on February 10, 2026, 07:56:16 PM
I'd tend to install them - at this point the original springs are probably a bit tired.
Post by: philip on February 11, 2026, 02:33:05 AM
Ok 1 side done, i have réinstalled the second spring
I have installed also a bolt on subframe connector.
Thanks for your help.
I will continu to investigate about these springs.....
Post by: philip on February 21, 2026, 09:17:58 AM
I have found a "2" on the passenger added leaf..(https://i.postimg.cc/kDrXzYRt/20260213-145539.jpg)
