Camaro Research Group Discussion => Restoration => Topic started by: hdptsr on December 26, 2025, 07:04:56 PM
Title: Carburetor linkage hitting bottom of air cleaner housing
Post by: hdptsr on December 26, 2025, 07:04:56 PM
I have a 1969 Z10 camaro with cowl induction.  I have the original setup with Quadra jet and a re-production air cleaner.  I am having trouble with the carb linkage hitting on the bottom of the air cleaner housing.  Any Suggestions?  Was there a factory spacer on the carburetor besides the small gasket?
Title: Re: Carburetor linkage hitting bottom of air cleaner housing
Post by: camaronut on December 27, 2025, 09:46:16 AM
You could add a few more carb horn gaskets to raise the air cleaner assembly away from the linkage.
Post by: Badshifter on December 27, 2025, 10:58:41 AM
https://www.heartbeatcitycamaro.com/13731/1969-Camaro-Cowl-Induction-Air-Cleaner-Extension-Fits%3A-350-Engines/?gad_source=1&gad_campaignid=23369922606&gbraid=0AAAAADpNiBbAhftVsf0bEHXDrNRZG4gXS&gclid=Cj0KCQiApL7KBhC7ARIsAD2Xq3BTtPD2hhlw-3XCPqKXYPkjrSjBc3iAlzaosGM2F38LwbfGOjIXqAwaAoC4EALw_wcB
The spacer you are looking for.
Post by: Stingr69 on December 27, 2025, 02:36:26 PM
Quote from: Badshifter on December 27, 2025, 10:58:41 AMhttps://www.heartbeatcitycamaro.com/13731/1969-Camaro-Cowl-Induction-Air-Cleaner-Extension-Fits%3A-350-Engines/?gad_source=1&gad_campaignid=23369922606&gbraid=0AAAAADpNiBbAhftVsf0bEHXDrNRZG4gXS&gclid=Cj0KCQiApL7KBhC7ARIsAD2Xq3BTtPD2hhlw-3XCPqKXYPkjrSjBc3iAlzaosGM2F38LwbfGOjIXqAwaAoC4EALw_wcB
No. That spacer fits between the top of the air cleaner flange and the flat hood seal flange.
Is it the top of the lever or is it the threaded rod/swivel hitting? Might need to move it to a different hole?
I would look at the Quadrajet part number to verify if it is correct first. If not, then consider bending the lever inward for clearance or grinding off some of the ample extra material on top part of the carb lever.  Something is not "original" here.
Post by: 68camaroz28 on December 27, 2025, 04:57:19 PM
fixed it here......   https://www.camaros.org/forum/index.php?topic=21797.0
Post by: Badshifter on December 27, 2025, 10:27:46 PM
Glad you solved it! Should have stayed in my (limited) area of knowledge!
