Does anyone who has a survivor 69 Z28 before June of 69. I would like to know if the carb base plate has a square notch on the drivers side rear mounting leg . This notch was apparently used for the upcoming 70 model year cable accelerator bracket.
Here is a reference photo. Lower right corner.
Here is the throttle cable bracket.
Original 4053 dated 934....no notch
Are you sure it's never been apart ? Thank's
Different levels of survivor? Yes carb was apart for new gaskets.
