Camaro Research Group Discussion => Restoration => Topic started by: ALLZS on March 18, 2022, 07:42:06 AM
Title: 1967 VALVE COVERS
Post by: ALLZS on March 18, 2022, 07:42:06 AM
what are  the correct valve covers for a 1967 Camaro rs 327  210 h/p where there different ones depending  on build date and plant built in
Title: Re: 1967 VALVE COVERS
Post by: MO on March 18, 2022, 04:26:36 PM
I'd think the stamped steel painted valve cover with Chevrolet script unless it came with the engine dress up option; then they would be chrome. All built at the same engine plant, so there shouldn't be a difference between NOR or LA built cars.
Post by: ALLZS on March 18, 2022, 05:39:55 PM
ok thanks for that info
Post by: Petes L48 on March 18, 2022, 09:50:40 PM
Painted script covers, no hole for a PCV valve since the vent tube was still used in 67.  See UPC 6 Sheets 4 and 5 in the 67 AIM.
The L48s had the chrome script covers, air cleaner lid, filler tube and cap on some.  There wasn't a separate engine dress up option.
Post by: bertfam on March 20, 2022, 02:07:28 PM
Here you go.
Post by: 68camaroz28 on March 20, 2022, 09:43:06 PM
that is one sweet original set  Ed.....
