Camaro Research Group Discussion => General Discussion => Topic started by: john302 on December 15, 2021, 04:52:14 PM
Title: Big block clutch adjusting rod and swivel
Post by: john302 on December 15, 2021, 04:52:14 PM
Does anyone know the gm part number for the threaded clutch adjusting rod and swivel for a 67-69 big block four speed ? thanks
Title: Re: Big block clutch adjusting rod and swivel
Post by: firstgenaddict on December 15, 2021, 06:39:39 PM
Don't know the part number but big blocks use a threaded tube and rod not the swivel block and rod.
Post by: bertfam on December 15, 2021, 07:26:50 PM
Per view A - Items 3 and 4 (and the production nut) in the attached. (P/N 9779202 and P/N 3840845)
Post by: firstgenaddict on December 16, 2021, 02:54:48 AM
My fault apparently 67-68 is different
69 used the tube and rod.
Post by: bertfam on December 16, 2021, 09:20:41 AM
No, all three years used the same linkage. (See the 1969 AIM sheet attached)
As a matter of fact, this same arrangement was used on Buick's, Oldsmobile's, Pontiac's, trucks, and other Chevrolet and GM years and models.
Post by: firstgenaddict on December 16, 2021, 02:22:21 PM
The originals with Bergy's L78 pacer are the tube and the rod- he doesn't have a Small block V8 Camaro so now I can't figure out which one.
I had to weld up the worn stud pin and file it back round.
Post by: bertfam on December 16, 2021, 02:30:54 PM
The small blocks used what you show in your drawing above (#17 and #18), but the big blocks used what I posted before. HOWEVER. (and this is a BIG however), If you're running headers on a big block, the original setup will hit the header tubes when you engage the clutch. You either have to fab up something that'll clear the header tubes or you can use the small block arrangement, which is what I'm using with the Hooker headers I have.
Post by: firstgenaddict on December 16, 2021, 02:35:27 PM
Thanks, perhaps that is the explanation.
Post by: john302 on December 17, 2021, 10:32:22 AM
yes it is the rod and swivel for a big block . thanks
