Camaro Research Group Discussion => Decoding/Numbers => Topic started by: jbtech on November 28, 2021, 03:09:57 PM
Title: NOS Coil Springs with Part Number without 2 Letter Code
Post by: jbtech on November 28, 2021, 03:09:57 PM
I purchased a few sets of NOS coil springs with tags but none have a 2 letter callout on the tag.
For example: The set I have here is part number 3955722
Are they correct for '69  "YP" or "YM" code or both?
Are springs with the same part number identical and the 2 letter code just to clarify application?
Thanks!
Jose
Title: Re: NOS Coil Springs with Part Number without 2 Letter Code
Post by: Gars68Tux on November 29, 2021, 12:26:20 AM
You can look it up in the AIM spring chart. Part numbers and codes are listed there.
Post by: ko-lek-tor on November 29, 2021, 03:35:35 AM
Quote from: Gars68Tux on November 29, 2021, 12:26:20 AM
Not what OP is asking. He is well aware of that chart he tells me
Post by: Gars68Tux on November 29, 2021, 07:48:07 AM
He's asking for the code for 3955722, right ? I don't have a 69 AIM, but the codes are listed in the 68 AIM, so I assume they were in the 69 AIM as well.  That part number isn't valid for 68.
Post by: 69Z28-RS on November 29, 2021, 08:52:32 AM
In attempt to answer his questions:
1.  The two letter codes were for factory workers to quickly grab the correct spring for the car they were working on; not necessary for sales across the counter later.'
2.  If the Part Number is the same, then the springs SHOULD be the same as was used in production.
Post by: Jonesy on November 29, 2021, 10:07:01 AM
I would think the best explanation is that these are over-the-counter replacement springs and they would not have the two letter code like the assembly line production springs did.
The 2 letter code helped aid the assembly line workers select the correct springs.
Post by: jbtech on November 29, 2021, 11:23:20 AM
Thank you all for your replies. I'm going to rephrase my question.
GM replacement coil springs are sold by part number and do not provide a 2 letter code on the tag like assembly line springs.
Does this mean that assembly line coil springs with identical part number but different 2 letter code are also identical?
For example is 3955722 YP an identical spring to 3955722 YM?
Jose
Post by: jdv69z on November 29, 2021, 11:45:53 AM
Yes.
Post by: bcmiller on November 29, 2021, 01:04:20 PM
Spring chart reference with some explanation on part number usage.
A new System of determining the correct front and rear Springs has been used for 1969 Camaro
passenger cars. The assembly plants use a computer to determine the correct spring based on
the RPO equipment on the dealer order.
This requires a new method of determining service springs. The information required to determine
the correct spring or springs is shown on the subsequent pages.
http://www.camaros.org/images/pages/chassis/69_spring_chart.pdf
Post by: Gars68Tux on November 29, 2021, 09:47:24 PM
 Thanks Bryon. I count 5 different ID codes for 3955722...I had no idea! ???
Post by: jbtech on November 30, 2021, 08:46:08 AM
Thank you all for the answers!
