Does anybody know if these Ansen / CP style valve covers for a big block clear the 11" brake boosters on a 68 Camaro?
Doubt they will fit. I had a similar set on my 68. Only had about 1/2" clearance to the booster. Yours look to be slightly taller.
with a set of tall covers you have to notch the end - last time I cut out the last 2 inches of the corner and flipped the removed piece over and tig'd it back into the cover as a relief.
