Does anyone have a picture of the correct markings on original 1969 Camaro big block exhaust manifold bolts?
I believe they would be the 'std' 'double circle marked bolt heads... Paragon Corvette has these in kits..
https://www.paragoncorvette.com/p-355204-exhaust-manifold-bolt-stud-kit.aspx
I can't see the heads on these bolts but most of mine have the double circle with 6 lines (grsde 8) going from the inner circle to the outer circle. My engine was built 08/21/1969. That doesn't mean that's correct for your engine as they bought bolts from different supplier....Joe
Big blocks use 2 different bolts one with a flange and one without the flange.
Cylinders 1 and 7 - 2 and 8 use bolts with flanges
Cylinders 3 and 5 - 4 and 6 use bolts without flanges.
